Author Topic: Size of 29" CRT needed.  (Read 1335 times)
Kman-Sweden
  • Up the Irons!
« on: January 25, 2010, 01:21:31 pm »
Hi everyone.
Does anyone know what the hight * width (normaly/generaly) is, including mounting hardware, on a 29" CRT?
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
Re: Size of 29" CRT needed.
« Reply #1 on: January 25, 2010, 02:20:21 pm »
classic crts are 3:4:5  makes a 29 inch 68/72 cm tv :  43,2cm  x 57,6cm  x 72 cm   . add 1 inch for each of the tv mounting brackets . arcade mounting frames will add a few more centimeters , but that differs a lot . it can be 3 cm or 10 cm on each side.  25,28 and 29 inch tubes usually come with a depth of 40-45 cm . only a few are shorter than 40 cm and mostly flat tubes are longer that curved ones .
« Last Edit: January 25, 2010, 02:25:13 pm by apfelanni »
