Author Topic: touch screen monitor not working from one side  (Read 1630 times)
abispac
  • Last login:February 09, 2026, 12:30:42 am
« on: January 23, 2010, 03:46:11 pm »
i bought 10 touch screen monitors from ebay ,9 of them work just fine but one, at the left end from top to bottom of the side of a finger the touchscreen does not work, i cheked and cables seem ok and no brakes in the glass, any ideas? thanks alot.
Kevin Mullins
    • Me on Myspace
Re: touch screen monitor not working from one side
« Reply #1 on: January 23, 2010, 04:11:23 pm »
Does the rest of the screen work correctly ?
Have you run a calibration on it ?
What type of microcontroller does it use ? (3M, ELO, etc)
I know 3M software has several options to try....Calibration, Edge Adjustment, Linearize and also has a feature to "reset" the controller which sometimes helps wonky touchscreens.
abispac
« Reply #2 on: January 23, 2010, 04:26:52 pm »
its was a calibratio issue, or maybe somenthing was loose inside because its working now, the other 9 where working ok with the same calibration. thanks anyway  :cheers:
