Author Topic: Spinner trouble  (Read 4186 times)
lowrider3121
  • Last login:September 15, 2013, 07:47:27 pm
Spinner trouble
« on: January 22, 2010, 06:01:31 pm »
Hey all just pickup a cheap spinner but can't get it to work in my games I'm running Mamewah as a front end spinner works in windows and in Mamewah just not in the game any ideals tried the tab input game but the game input does not see it. The spinner is a EZMount Arcade Spinner.
ahofle
    • Arcade Ambience Project
Re: Spinner trouble
« Reply #1 on: January 22, 2010, 06:03:20 pm »
lowrider3121
Re: Spinner trouble
« Reply #2 on: January 22, 2010, 06:46:57 pm »
I'm running MAME 0.136 Windows command-line binaries can't find the folder to change the 0 to a 1
Hoopz
  • Intellivision Rocks!
Re: Spinner trouble
« Reply #3 on: January 22, 2010, 07:03:31 pm »
You generate a mame.ini file but using the command mame -cc
Search "mame -cc" or post back if you can't get it to work.
Edit: search WITH the quotes or else you'll get eleventy bazillion results.
« Last Edit: January 22, 2010, 07:23:02 pm by Hoopz »
lowrider3121
Re: Spinner trouble
« Reply #4 on: January 22, 2010, 07:29:12 pm »
still no luck
Hoopz
Re: Spinner trouble
« Reply #5 on: January 22, 2010, 07:31:43 pm »
lowrider3121
Re: Spinner trouble
« Reply #6 on: January 22, 2010, 07:43:51 pm »
os is mamewah and mame is MAME 0.136 Windows command-line binaries. pc is win 2000
Hoopz
Re: Spinner trouble
« Reply #7 on: January 22, 2010, 07:48:32 pm »
Do you know how to pull up a command prompt?  It looks like an old DOS-style window?
I don't know how Win 2000 handles that.
Hoopz
Re: Spinner trouble
« Reply #8 on: January 22, 2010, 07:49:18 pm »
Windows NT, 2000 and XP users
   1. Click Start.
   2. Click Run.
   3. Type cmd or command and press enter.
can you do this?
lowrider3121
Re: Spinner trouble
« Reply #9 on: January 22, 2010, 07:51:04 pm »
sure can
Hoopz
Re: Spinner trouble
« Reply #10 on: January 22, 2010, 07:54:46 pm »
sure can
Ok, good.  Not trying to treat you like a four year old....  :)
Where is your mame folder located?
Something like in the C:/ drive?  Or c:/games/mame?  Or where?
lowrider3121
Re: Spinner trouble
« Reply #11 on: January 22, 2010, 07:56:04 pm »
C:\juegos\mame
Hoopz
Re: Spinner trouble
« Reply #12 on: January 22, 2010, 07:58:55 pm »
Good.  If you know that, you can do this pretty easily.
In the command prompt window, type:
cd\
It should take you to C:\
Now type cd juegos
You should now be at c:\juegos
Now type cd mame
You should now be at c:\juegos\mame
EDIT - Hit ENTER after each step so cd\  ENTER
lowrider3121
Re: Spinner trouble
« Reply #13 on: January 22, 2010, 08:01:57 pm »
okay there now
Hoopz
Re: Spinner trouble
« Reply #14 on: January 22, 2010, 08:05:34 pm »
okay there now
Almost done.
Just type mame -cc  ENTER
Then go to your mame folder itself.  You should now see the mame.ini file.  Open it up.  It should open in notepad or whatever text editor Win 2k came with.  Look for a line that says Mouse 0 (or mouse 1).  If it's 0, change it to 1 and save the file before closing it.
Your spinner should work now.
lowrider3121
Re: Spinner trouble
« Reply #15 on: January 22, 2010, 08:11:00 pm »
it works thank you so much
Hoopz
Re: Spinner trouble
« Reply #16 on: January 22, 2010, 08:11:53 pm »
Glad to help.  What are you playing now?  Tempest, Star Trek, Arkanoid?
