Author Topic: K7000 bottom line problem  (Read 1442 times)
Cisek
  • Last login:May 19, 2023, 07:35:14 am
« on: January 21, 2010, 06:56:33 pm »
Hi
I almost fully repaired my monitor. My problem is there that the bottom of image is squezzed. Already tried adjusting 50/60 hz pot adjustments and it didn't improve, shortening the image with v-size pot also didn't help.
http://img22.imageshack.us/i/20080118505.jpg/
southmonitor
  • Last login:September 18, 2010, 08:10:10 pm
Re: K7000 bottom line problem
« Reply #1 on: January 24, 2010, 01:35:27 pm »
You have a vertical linearity problem there. Likely to be one of the electrolithic caps near the Vertical Out IC or in the Power Supply. Replace all of them if you are not sure which one is bad. Get a cap kit somewhere for that model.
MK3FAN
« Reply #2 on: January 24, 2010, 05:00:59 pm »
I was going to suggest adjusting the 50-60 pot, but if you already tried that, then yes, a cap kit is the next step.
Cisek
« Reply #3 on: January 24, 2010, 05:56:52 pm »
I made a capkit, however it didn't help me with this.
