Author Topic: Jamma Harness Monitor connection help needed! --pics and model no. added  (Read 2688 times)
bdsjake
  • Last login:September 18, 2017, 12:08:23 am
  • livefree
I bought a "jamma loom" and it is perfect except for the monitor connector.  I have a MAME cab i built years ago and I am converting to a 60-1 board, it has a arcade resolution monitor I bought from HAPPs in around 2000-2001 that I ran from an ArcadeVGA graphics card.  Anyway, the connector to the monitor board has six wires and six plugs ( a pic of the connector that I pulled from the monitor board is attached if can)....but the jamma loom has a 5 pin connector!
Can I buy a correct jamma loom with the connector I need, or someone tell me  how to wire it up, I can cut and splice the wires if I have to, I was just hoping for the easiest solution.  If I recall reading about this stuff (again years ago), maybe the V and H synch can be combined???
any help appreciated, thanks!
« Last Edit: January 24, 2010, 11:55:19 pm by bdsjake »
SirPeale
  • Green Mountain Man
Re: Jamma Harness Monitor connection help needed!
« Reply #1 on: January 23, 2010, 09:25:01 am »
Knowing what monitor you have would be a great help in this situation.
bdsjake
  • livefree
« Reply #2 on: January 24, 2010, 11:53:21 pm »
The sticker on the monitor says Vision Pro Model No. MTG 1901CN, I will try to attached a pic, and also a pic of the connector on the jamma loom.
I guess I should cut the Arcadevga cord and use the original 6 pin connector to the monitor, attaching that to the jamma loom in place of the 5 pin connector, but what wires do i connect together to go from 5 wires on jamma loom to 6 on the monitor connector?
bdsjake
  • livefree
« Reply #3 on: January 24, 2010, 11:54:03 pm »
here is the jamma 5 pin,
Ken Layton
  • Guru
  • Technician
« Reply #4 on: January 25, 2010, 11:07:13 am »
That's a Japanese video connector. Definitely NOT American standard.
lilshawn
  • Last login:Yesterday at 11:14:57 am
Re: Jamma Harness Monitor connection help needed! --pics and model no. added
« Reply #5 on: January 27, 2010, 12:32:32 am »
99% sure you got...
red=red
blue=blue
green=green
black=ground
white=sync
yellow-composite sync
i would hack off that non-standard connector and just put the regular connector on it.
IE match up the colors, i would think the white and white would go together, but you may have to try white to yellow
« Last Edit: January 27, 2010, 12:34:58 am by lilshawn »
