Author Topic: Tools to own  (Read 3398 times)
asr10 user
  • Last login:April 26, 2010, 04:00:20 am
Tools to own
« on: January 20, 2010, 12:07:48 am »
So im looking at making my first cabinet, after years of joystick modding.  But am unsure of which tools to get.  I already have a drill and a jigsaw.  I keep reading about routers and circular saws and other stuff.  Which power tools are required and highly suggested for everything?
Nacimroc
  • Last login:October 20, 2015, 03:46:25 pm
Re: Tools to own
« Reply #1 on: January 20, 2010, 04:59:07 am »
A Router is a must! Its used to match sides exactly (flush trim bit), cut slots for t-molding, making holes in you CP acrylic, flush trimming laminate (although I used an angle grinder at first  :lol :lol)
For the price its worth getting a circular saw aswell! To keep all the pieces lining up perfect, otherwise you'll spend hours messing with rasps and sanding. Try to get one with a laser site. Very helpful and only a fraction extra.
Don't worry, this hobby is a drug so you will definitely get more use out of them! You could easily get both for 50 quid and they'd last you for years!
Franco B
Re: Tools to own
« Reply #2 on: January 20, 2010, 05:28:04 am »
I think you can get away with a drill, jigsaw and router.
I have a circular saw but I can count on my left hand the amount of times I have used it. I always jigsaw my cuts and then use a router, straight edge and flush trim bit to finish perfectly straight.
You definitely want to purchase a router, they are the most versatile tool you will ever use.
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Tools to own
« Reply #3 on: January 20, 2010, 11:17:18 am »
Yes a router a good tool and they can be purchased cheaply, however then do not last if you do a lot of work, I went through 3 before I got a Makita.
A circular saw would be good, I tend to use a straight edge clamped (speed clamps are purfect) to the boards to be cut to run the saw against produces the same cut boards.
I do not see hand planes mentioned on this forum at all but I use them all the time for finishin off prior to sanding.
Regards
Alan Hood
ami-man
UK
Re: Tools to own
« Reply #4 on: January 20, 2010, 12:42:19 pm »
Some sort of power sander usually comes in pretty handy.
Ed_McCarron
Re: Tools to own
« Reply #5 on: January 20, 2010, 04:14:39 pm »
All of them.
