Author Topic: Medium res 25hz games (Paperboy, Championship Sprint etc.) on WG D9800?  (Read 5635 times)
dekar24k
  • Last login:April 28, 2019, 03:50:11 pm
    • ArcadeForum.com
I have a question for those with a WG D9800 (or equal) monitor; what resolution do you run medium res 25hz games at (Paperboy, 720, Championship Sprint etc.)?
AVRes set those games to 512x448 and they flicker like mad. I get a headache after playing for 30 seconds. I really want to play Championship Sprint as it's a really cool game. :)
Finished project: "The Saloon Arcade" - 2 player upright cabinet
Joystick.net - Retro gaming news and reviews
isucamper
  • Last login:November 25, 2019, 05:13:08 pm
  • I'm a slasher... of prices!!
    • my project arcade blog
Re: Medium res 25hz games (Paperboy, Championship Sprint etc.) on WG D9800?
« Reply #1 on: January 15, 2010, 12:42:04 pm »
I can't remember what resolution I have them at (I'll fire up the cab and check this weekend for you) but I do know that medium res games don't look good on my 9800.  It doesn't seem to like the signals in this range.  I don't get flicker, but the games have an hourglass shape to them I can't tweak out with the OSD controls.
I'm very happy with the monitor, but it definitely has a weakness in this area.
THE SYSTEM          Popeye
dekar24k
    • ArcadeForum.com
« Reply #2 on: January 15, 2010, 03:21:51 pm »
Hmm .. The reason I'm asking is because I read a review (don't remember the URL) where it said that the D9800 looked awesome in 25hz med-res games. Anyways, I appreciate that you'll take a look. Thanks! :)
Oh and while you're at it, do you mind checking what you've set your vertical games to as well (newer games like Aero Fighters etc.)? :) Bomb Jack and older vertical games are working great but I haven't figured out what res to set the others at yet without hw stretch or cutting off too much of the game.
MonMotha
« Reply #3 on: January 15, 2010, 03:50:26 pm »
Medium Res aka EGA is usually in the neighborhood of 512x384 progressive.  Standard Res aka CGA is either ~320x240 progressive or 640x480 interlaced.  Some games have a resolution vs. refresh tradeoff (higher resolution means lower refresh and more flicker).  Exact resolution used varies by game.
512x448 seems unusually high and a strange pixel aspect ratio (though those are not unheard of with arcade games).  I kinda wonder if perhaps you've chosen a CGA compatible resolution and are software scaling.  That resolution at CGA would be interlaced which might explain the flicker.  If it's progressive EGA compatible timings, it would be at a low framerate, which might also explain the flickering.
ahofle
    • Arcade Ambience Project
« Reply #4 on: January 15, 2010, 10:18:33 pm »
Definitely 512x384
dekar24k
    • ArcadeForum.com
« Reply #5 on: January 16, 2010, 02:55:17 am »
Thanks for all the advice guys. I will try setting it to 512x384 now and see if it looks better!
dekar24k
    • ArcadeForum.com
« Reply #6 on: January 16, 2010, 04:49:45 am »
I tried 512x384 and it looked awesome, except for one small flaw. I couldn't quite center the image the way I wanted to (I couldn't move the image to the left or right with the OSD functions, only resize it). Are you guys experiencing this as well with your D9800's?
isucamper
« Reply #7 on: January 16, 2010, 12:29:17 pm »
I'm running 512x384 for 720, narc, and paperboy and i'm running 496x384 for virtua fighter.  VF looks great on my monitor, but the other three have the weird hour glass shape that I've complained about in the past.  Even the MK games have it (which I run at 399x253) but its not as bad.  I can't get rid of it by tweaking the controls.  All other resolutions look great which is why I haven't complained too loudly about this.
And yes, I can't seem to center the 512x384 games either.  Do you get the hour glass shape?  I also get pretty bad warping during paperboy as the screen scrolls.  I'm using soft15KHz by the way.
THE SYSTEM          Popeye
secret80sman
  • Last login:March 14, 2013, 07:04:31 pm
    • The Ultimate 80's Tribute Band
« Reply #8 on: January 16, 2010, 02:58:09 pm »
Have you tried the individual screen adjustment controls within the game itself instead of just on the OSD? I have a 9800 but have yet to play these games. Still trying to pull myself away from Frenzy and Amidar (my faves this week).  :P
dekar24k
    • ArcadeForum.com
« Reply #9 on: January 16, 2010, 05:03:47 pm »
Same happens to me, weird hour glass shape which I can't get rid of with the OSD. The MK games look great though, can't remember having trouble with those.
Also, I haven't played Paperboy alot yet, so don't know about warping. As long as I can play Championship Sprint then I'll be happy. :)
dekar24k
    • ArcadeForum.com
« Reply #10 on: January 16, 2010, 05:05:23 pm »
Haven't tried it, but I don't think it'll work as the screen/image itself can't be moved to the right at all. So there's something about the resolution that the D9800 don't like.
« Reply #11 on: January 17, 2010, 01:51:47 pm »
Might be a dumb question but would an older version of Mame be worth a try?
I'm hoping to order a DG9800 as soon as I get my taxes done.   ;D  I would love to see this problem resolved first but don't see this as a show stopper.
dekar24k
    • ArcadeForum.com
« Reply #12 on: January 17, 2010, 03:12:23 pm »
I don't think it has to do with MAME, rather how the D9800 handles the 512x384 resolution. I don't see it as a "problem" though, as the picture looks great and there's only a slight percentage of the right side of the screen which is not covered by it.
ahofle
« Reply #13 on: January 18, 2010, 01:49:02 am »
Seems like pincushion should at least help minimize that a little bit.  Does it not help?
isucamper
« Reply #14 on: January 18, 2010, 08:31:54 am »
It does help but there's always that buldge that won't go away.  And you'll notice in the screenshot I posted, the bottom of the picture is angleing in and the top is angleing out.  Pincushion won't bring them both in.  I have messed extenstively with the controls to try and fix it and I can't really get close.
THE SYSTEM          Popeye
MonMotha
« Reply #15 on: January 18, 2010, 10:58:21 am »
Have you tried adjusting the "trapezoid" control?  It looks like you could adjust that out using a combination of "trapezoid", "pincushion", and maybe (if it has it) "bottom corner", probably adjusted mostly in that order.  The adjustments interact a little, so you may have to go back and forth for a while.
isucamper
« Reply #16 on: January 18, 2010, 01:15:44 pm »
yeah.  i've messed with it extensively.  perhaps a professional calibrater could do better than me, but even messing with the trapazoid to even up the top and bottom, there's still the bulge in the middle
THE SYSTEM          Popeye
dekar24k
    • ArcadeForum.com
« Reply #17 on: January 19, 2010, 12:29:03 pm »
Another thing that's annoying me is the fact that I never get that "perfect" image. I just adjusted every single available resolution with Nokia Monitor test earlier today and then I started testing different games. Some games were centered/stretched correctly and some weren't. If I adjusted one game, then another was completely off.
Are you all (D9800 owners) experiencing the same?
ssndk
  • Last login:January 22, 2010, 05:59:03 pm
« Reply #18 on: January 22, 2010, 05:52:26 pm »
I think this is perfectly normal. I found it annoying too at first.. I have a D9400 (same chassis) and you wont have every single game fit perfectly on the screen (unless you adjust your screen settings in some games). You'll have to fiddle around with the settings until all games are either perfect or acceptable. I think I've found settings where almost all the horizontal games are either perfect or very acceptable. For vertical games its more difficult (without rotating the monitor) and sometimes requires the software stretch.
ahofle
« Reply #19 on: January 22, 2010, 06:07:14 pm »
Not to thread hijack, but the solution for vertical games is to select a resolution with more horizontal pixels.
For example, Centipede/Donkey Kong/etc: MAME wants to select 256x256 or 321x256.  352x256 looks WAY better.
dekar24k
    • ArcadeForum.com
« Reply #20 on: January 23, 2010, 04:12:36 am »
Good to hear. :)
Although I believe I have a close-to-perfect setup now as well. I went through all my MAME favorites last night (more than 150, at least) and they are all looking good now. Most games are perfectly stretched, those that aren't are perfectly centered although not stretched to the very corners. So I'm happy with my setup now, as long as everyone else are having the same "issues". ;)
dekar24k
    • ArcadeForum.com
« Reply #21 on: January 23, 2010, 04:13:33 am »
Weird thing is that Donkey Kong looks perfect on my setup, but Pac-Man/Ms. Pac-Man etc. is clipped. I thought these games ran at the same res. I will try setting Ms. Pac-Man/Pac-Man etc at 352x256 later and see how it turns out. Thanks for the tip!
