Author Topic: WG9800 losing signal every few minutes  (Read 1401 times)
secret80sman
  • Last login:March 14, 2013, 07:04:31 pm
    • The Ultimate 80's Tribute Band
« on: January 14, 2010, 08:19:00 am »
To be clear this does not happen during game play but if left unattended for a few minutes the monitor says 'NO SIGNAL IN'. Once I move the mouse or trackball the screen returns but this sucks because I want the front end to be displaying at all times. I turned off the screen saver, turned it on and neither option works. Any suggestions would be greatly appreciated.  ???
Thanks in advance,
MG
isucamper
    • my project arcade blog
Re: WG9800 losing signal every few minutes
« Reply #1 on: January 14, 2010, 08:35:30 am »
Sounds like your PC is in power save mode (stops sending a signal to the monitor after a period of inactivity) or it's going to sleep or something.  Go back into where you set up your screen saver and shut all that stuff off.
THE SYSTEM          Popeye
dekar24k
  • Last login:April 28, 2019, 03:50:11 pm
    • ArcadeForum.com
« Reply #2 on: January 14, 2010, 01:37:38 pm »
Indeed. Check your PC's power settings and disable stuff like "Turn off monitor after xx minutes" etc. I have all power saving features disabled on my cab. On Windows XP you will find it under Start -> Control panel -> Power options
Finished project: "The Saloon Arcade" - 2 player upright cabinet
Joystick.net - Retro gaming news and reviews
secret80sman
« Reply #3 on: January 15, 2010, 08:42:58 am »
Guys, I can't thank you enough, this was exactly the problem! Those clowns at WG tech support didn't even think of what should have been the most obvious first solution. I just can't believe I didn't think of it, ah well, live and learn. Thanks again.
dekar24k
    • ArcadeForum.com
« Reply #4 on: January 15, 2010, 08:47:58 am »
:) Glad it wasn't a bigger issue!
