Author Topic: Drilling more HotRod buttons...  (Read 4179 times)
TeutonicDarkness
  • Last login:July 16, 2019, 10:54:16 pm
« on: January 13, 2010, 10:10:51 pm »
Hello,
 I very recently decided to Mod my Hotrod SE.
After recently building my Aimtrack lightgun ...
Well I felt Confident enough to tap into the HotRod " Secret buttons".
I searched every store available here for the hole drilling bits..
Unfortunately they only had 1 inch and 1 1/4 hole drilling bits.
1 inch was too small and 1 1/4 was too big.
I would love to know what the Exact size for this is?
Is it standard or possibly a metric size?
Where is a good Online place to order an assortment for this
hobby at a good price?
I ended up using the 1 inch bit and just Dremelling out until I got
my new buttons installed :angry:
But it still turned out fairly well My HotRod now has Esc and Pause!
I also added a Green Arcade button in the back.
This powers up my  Mame PC.  ;)
Franco B
Re: Drilling more HotRod buttons...
« Reply #1 on: January 14, 2010, 01:19:55 am »
Funnily enough its 1 1/8" for standard 'Happ' buttons :)
You can also use a 28mm bit but they can be a little tight.
I'm not sure what availability is like in the states but I haven't had any problem buying either size forstner bits over here in the UK.
I'm sure someone in the US will be able to point you in the right direction for a set.
Enjoy your new buttons :)
TeutonicDarkness
« Reply #2 on: January 14, 2010, 06:48:26 pm »
Thanks,
 So 1 1/8 it is. :)
I defiantly can't get that size here in my town.  :(
So Will someone recommend a good online store that Sells
an assortment that will come in handy for this hobby?
Sure I could google... but would love to hear of a Good Value set
and some of good quality.
Anyone?  ::)
TeutonicDarkness
« Reply #3 on: January 17, 2010, 01:30:54 pm »
Anyone?
Encryptor
  • Trade Count: (+34)
  • Last login:December 21, 2023, 08:01:18 pm
« Reply #4 on: January 17, 2010, 04:34:23 pm »
Thanks,
 So 1 1/8 it is. :)
You don't have a hardware store or a Sears in anywhere near you? 1 1/8 is a pretty common size I believe.
Encryptor
  • Last login:July 23, 2025, 07:04:20 pm
« Reply #5 on: January 18, 2010, 10:56:37 am »
TeutonicDarkness
« Reply #6 on: January 18, 2010, 07:44:32 pm »
Thanks,
 So 1 1/8 it is. :)
Encryptor
 I would think it would be too.
But No!
We have a Home Depot here and they don't have a 1 1/8.
TeutonicDarkness
« Reply #8 on: January 19, 2010, 08:59:38 pm »
http://www.homedepot.com/Tools-Hardware-Power-Tool-Accessories-Drill-Bits-Auger-Spade/h_d1/N-5yc1vZ1xitZb8mw/R-100352499/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
 Is a Spade better or a hole saw?
( couldn't think of the name earlier when I posted )
I might can get a spade .. I had been looking for a hole saw.
I will look again this weekend and see if they have those Spade's.
I'm definitely curious which will give the best results?
Franco B
« Reply #9 on: January 20, 2010, 03:58:37 am »
I personally would recommend a forstner bit over a hole saw or spade bit for the majority of holes you will be drilling, especially the 1 1/8" etc CP holes.
[Forstner Bit - Wikipedia Link]
Forum Links:
[forstner bit advice]
[Preferred place to buy Forstner Bit Online?]
I linked to a couple of threads there but if you search for 'forstner' in the woodworking board you will find a shed load of relevent threads.
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
« Reply #10 on: January 21, 2010, 04:55:06 am »
Hi,
A good addition to anyones took kit is one of those conecut drills (a tapered drill) they come in about two or three sizes.
They will cut through thin steel but are great on perspex etc.
Regards
Alan Hood
ami-man
UK
TeutonicDarkness
« Reply #11 on: January 21, 2010, 08:09:55 pm »
 Thanks everyone for the Advise!
I will try to find Fostner bits around here.
If not I will try the internet.
popsicle
  • Last login:August 25, 2025, 05:51:59 pm
« Reply #12 on: July 28, 2010, 05:13:33 pm »
How hard was it to add the extra buttons to the Hotrod (not the drilling part, but the soldering/wiring and such)?
I have a Hotrod SE also (already integrated in to the cab) but I've been using button combos for escape and such... wishing I had a dedicated button
BobA
  • What Me Worry?
« Reply #13 on: July 28, 2010, 05:42:25 pm »
Here is the info you need to connect to the HotRod Controller
