Author Topic: Weight of empty plywood cab?  (Read 1513 times)
Dafu
  • Last login:October 05, 2015, 10:06:43 pm
« on: January 08, 2010, 05:14:47 pm »
Any idea what the weight of an empty plywood cab is? I'm picking one up over the weekend, and I'm wondering if I'll need help moving it, or if I can just tilt/push it onto a truck myself. The seller has a bad back and will not be able to assist:(
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: Weight of empty plywood cab?
« Reply #1 on: January 08, 2010, 05:20:54 pm »
I have that same cab and they are pretty light. Even more so if there is no monitor.
If you can take a hand cart to move the cab up to the truck, you should be OK tilting it in on your own.
Working: Not Enough
Projects: Too Many
Progress: None
