December 04, 2025, 08:23:07 am
thanks guys these sounds exactly like what im looking fori think Solenoid are the cheaper method, my question is, if the power is cut off from the solenoid will the piston return to its in position?
You could use a servo like in the "Most Useless Machine EVER" project on Instructables.
Quote from: crashwg on January 07, 2010, 01:36:57 pmYou could use a servo like in the "Most Useless Machine EVER" project on Instructables.I clicked this link and a moment later, it tried to install malware. I go to instructables all the time, so I don't know why it happened. Just a warning.
Quote from: Ginsu Victim on January 07, 2010, 04:17:44 pmQuote from: crashwg on January 07, 2010, 01:36:57 pmYou could use a servo like in the "Most Useless Machine EVER" project on Instructables.I clicked this link and a moment later, it tried to install malware. I go to instructables all the time, so I don't know why it happened. Just a warning.most of the time this means either the site has been hacked (happens all the time) or they are running a banner ad with an infection vector in there. but in ALL cases it means your machine is not properly patched / updated. stop using IE6
yup guys it was a flimsy flex ribbon very very small...... so I decided to go with the selonoid worked like a charm, wired it to a small pushbutton that i press and that triggers the selonoid to push the ps2 power button.
