Author Topic: Quick Sheller - v 0.92 released  (Read 38522 times)
Lave Laar
  • Last login:January 04, 2022, 06:23:13 am
    • Freeware arcade related programs
« on: January 03, 2010, 02:29:19 pm »
I've release a new program called Quick Sheller.
It's a program to aid in the job of hiding windows.
Before you ask, I know that Instant Sheller already exists and I think it's an excellent program.
I wanted a program that could do the same and didn't need the .NET runtime files installed.
It should incorporate most of the things described in the "Hiding Windows" section in the Wiki.
Some of the ideas ("Turn off event sounds" and "Disable windows animations")  I got from Instant Sheller.
If you want to try it you can get it here.
« Last Edit: February 13, 2010, 09:09:53 am by Lave Laar »
Hoopz
  • Intellivision Rocks!
Re: Quick Sheller
« Reply #1 on: January 03, 2010, 04:14:01 pm »
Thanks!  I'll try this soon a little project that I did over Christmas for my daughters.
Re: Quick Sheller
« Reply #2 on: January 03, 2010, 05:49:39 pm »
Looks cool
Oh, you +will+ be assimilated.  ;)
taylormadelv
  • Last login:February 18, 2019, 05:46:59 pm
Re: Quick Sheller
« Reply #3 on: January 07, 2010, 06:34:39 pm »
Works great. :applaud: Super easy. I had to re-read the "hiding Windows" wiki to get back to the desktop.
« Last Edit: January 07, 2010, 07:48:14 pm by taylormadelv »
Gorotsuki
  • Last login:March 05, 2011, 10:51:25 pm
Re: Quick Sheller
« Reply #4 on: January 07, 2010, 06:50:32 pm »
Thank you.
I'm going to give it a try.
cipriani2k
  • Last login:March 27, 2024, 05:58:18 pm
  • All I want is everything.
Re: Quick Sheller
« Reply #5 on: January 08, 2010, 05:20:03 am »
hmm, this seems insanely idiot proof. That being the case, I cant wait to try this out
Lave Laar
Re: Quick Sheller
« Reply #6 on: January 09, 2010, 04:18:52 pm »
I've released a new version 0.91
New in this release:
* Added support for running a vb-script or a batch-file directly as the shell
* Example vbs and bat files included with the program
* Some minor cosmetic changes
The ability to shell vb-scripts and batch-files is useful if you need to start certain programs before your FE starts.
I would suggest using the vb-script method as it will not bring up the ugly command window when executing the commands.
Available here.
Yoeddy1
  • Last login:September 15, 2022, 12:40:23 am
Re: Quick Sheller - v 0.91 released
« Reply #7 on: January 17, 2010, 01:22:52 am »
Question that I'm sure many are wondering:
Does it work with Vista or Windows 7 32 and 64 bit?
abispac
  • Last login:February 09, 2026, 12:30:42 am
« Reply #8 on: January 17, 2010, 12:56:34 pm »
works super nice, on one of my machines , i did the undo button and dint restart , did the apply changes again and everything look normal, but when i try to undo things and restart again the app its still shelled, only in one of 4 machines.
SephYuyX
  • Last login:November 28, 2013, 11:40:04 am
  • I Am, Who I Am.
« Reply #9 on: January 23, 2010, 10:54:52 pm »
Looks good, going to try this for myself.
While im here, does anyone know of a good place for MAME themed boot screens and intro vids while the FE boots?
« Last Edit: January 23, 2010, 10:59:03 pm by SephYuyX »
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« Reply #10 on: February 07, 2010, 05:32:01 pm »
I tried this out with xp media center 2005 and everything worked except hiding the boot screen.  Not sure why this is, but I was wondering if the media center boot logo is located in a location different from the other editions of xp.
Lave Laar
Re: Quick Sheller - v 0.92 released
« Reply #11 on: February 13, 2010, 09:08:35 am »
I suspect this has got something to do the way I detect which line to change in the boot.ini file.
Version 0.91 search for "WINDOWS="Microsoft Windows XP" and then add the correct switches at the end of that line if it's not already changed.
Your media-edition boot.ini file probably says something like "WINDOWS="Microsoft Windows Media Center Edition".
I've released a new version that changes the search-pattern to "\WINDOWS="".  This should be more universal, I hope.
Available here
Popcorrin
« Reply #12 on: February 13, 2010, 09:22:43 pm »
That fixed it.  Thanks
  • Last login:Today at 11:49:10 am
« Reply #13 on: March 01, 2010, 02:09:00 pm »
Is this easy to "undo" if it doesn't work the way I hope it works?
Lave Laar
« Reply #14 on: March 02, 2010, 06:04:52 pm »
Yes.  It does have an undo-function.
All changes made to the registry is saved to a reg-file in the program folder.
It will also make a copy of the boot.ini file.
Basically it follows the steps described in the "Hiding Windows" section of the wiki.
You can make a copy of the reg-file before running the undo-function to see what changes has been made and then follow the wiki, if for some odd reason the undo doesn't work as it should.
« Reply #15 on: March 03, 2010, 10:53:51 am »
What if I've already made some changes that are listed in the wiki (I got rid of the pop-up balloons).
Thanks!!   :cheers:
Lave Laar
« Reply #16 on: March 03, 2010, 11:34:58 am »
If you've already made some changes, QS will redo them when you press the "Apply changes" button.
If you have the balloon pop-ups disabled before you run QS, the pop-ups will still be disabled after running QS's undo-function.
QS undo-function should put WinXP back to the state it was in before applying the changes as it backup the values that are currently in the registry.
Havok
« Reply #17 on: March 04, 2010, 12:38:50 pm »
Anyone tried this yet with Windows 7 64bit?
tspeirs
  • Last login:July 23, 2020, 07:44:52 am
« Reply #18 on: March 04, 2010, 02:57:30 pm »
It really is the greatest form of flattery when someone uses your idea, and I dont have a problem, but it would be nice to get a credit on the downlod site or in the app. Like I said don't have a problem though, its not like its a commerical app or anything.
Lave Laar
« Reply #19 on: March 04, 2010, 06:20:24 pm »
It will not work properly with Windows 7.  Only with windows XP.
Not sure what you're talking about.  I've credited Instant Sheller for the two ideas I took from it.  Both here in the forums and in the readme.txt file of the program.   ???
tspeirs
« Reply #20 on: March 06, 2010, 05:03:23 am »
Its not a big deal. I think my point really is that the entire thing and idea is based on instantsheller. Like I said its not a big deal.
andrewbean90
  • Last login:October 04, 2012, 05:55:56 am
  • do you like it?
« Reply #21 on: March 06, 2010, 07:53:45 am »
I think its cool
« Reply #22 on: March 06, 2010, 07:57:19 am »
Excellent.  Thanks!!  I think I'm going to try it today...
« Reply #23 on: April 25, 2010, 03:08:52 pm »
OK, I'm finally working up the nerve for this... one last question - what happens when I exit my front-end?  Will it go back to windows desktop so I can use the computer normally like for editing gamelists and moving files around and stuff??
« Reply #24 on: April 25, 2010, 03:26:42 pm »
Ugh.  It didn't seem to work... I still see the XP load screen and all of the start-up sounds.  The mouse pointer is also white on boot-up.  So.... how do I undo this?  I can't seem to exit to my desktop - when I exit my front end I'm brought to a blank screen!
Any help would be great.  Thanks!!
« Reply #25 on: April 25, 2010, 03:52:30 pm »
OK, now I'm a bit worried - I managed to run QS again by hitting CCTR-ALT-DEL and running it through the task manager.  I clicked the "Undo" button and rebooted - it didn't undo anything!  How do I get windows back???
« Reply #26 on: April 25, 2010, 07:06:58 pm »
OK, I was able to manually run the system restore and I restored everything to the way it was yesterday afternoon.  Whew!  I guess I'll have to do the XP hiding manually.  I like the idea of the sheller but I don't think I'm computer literate enough to be comfortable.   :cheers:
Bender
« Reply #27 on: July 16, 2010, 10:30:08 am »
I'm in the same boat the "Undo" doesn't do anything
how do I undo this :banghead:
Bender
« Reply #28 on: July 19, 2010, 03:39:13 pm »
ok the Undo feature is a little buggy
this is What I've figured out so far
First off it a good idea to set up you Front End to be able to exit to window before you shell it (this will save a lot of headache if there are any problems)
if you make one set of changes and don't have to undo anything this program works great
If you do want to change anything you must undo everything you already did FIRST, this seemed to work for everything but the shelled program so, after the first restart, I check the box for shelling and left it blank, then restarted a second time and I was back to windows!
Then started over with a new set of changes and everything seems to be good
one other thing if you are replacing the startup image it MUST be: 640x480, indexed color space, with 16 colors(or less), 4-bit, bmp, with no compression
I would also set it to 72dpi but I'm not sure that matters
if this image is not right windows won't start
« Last Edit: July 19, 2010, 03:43:36 pm by Bender »
pitufo
  • Last login:February 21, 2011, 07:50:44 am
« Reply #29 on: December 20, 2010, 02:19:01 pm »
thx  :woot
EVEGames
  • Last login:December 03, 2025, 10:06:10 pm
« Reply #30 on: December 21, 2010, 12:57:00 pm »
Bender, that's a very good tip.  The only part that I'm not sure how to accomplish is "indexed color space"... any tips on how to make sure a picture has indexed color space?  And if possible, how to accomplish this in Paint Shop Pro specifically, although I'm sure most people use Photo Shop.
Bender
« Reply #31 on: December 22, 2010, 02:06:02 pm »
sorry I don't know Paint shop pro
in photoshop it's under Image/Mode
androtaz08
  • Last login:October 09, 2024, 07:17:01 am
« Reply #32 on: October 29, 2011, 10:51:08 pm »
anyone ever sort out the undo issue?
sega_mad
  • Last login:July 09, 2015, 04:03:08 am
« Reply #33 on: February 14, 2012, 01:17:56 am »
Lave Laar....You are a Legend!! :burgerking:
After upgrading to XP 64 Bit and all new gear (1155 M/B, 2500K CPU, HD4890 video card)...I couldn't totally hide windows (manually, following the "how to guide"), even though I had it runing perfectly on my 32 bit XP computer.
Found your program...ran it, and had it running perfectly in minutes.
The only problem I found was that the login screen still shows for a very brief second prior going to the front end??
Any idea how to fix this?
Thanks again for a great app
« Last Edit: February 14, 2012, 02:58:30 am by sega_mad »
IG-88
« Reply #34 on: December 04, 2012, 08:05:52 pm »
Hey Lave Laar, I realize this is a long shot but I was wondering if this project ever got finished or whats up with it? I've been looking for a shell program for win98 (I know, I know, long story) and stumbled across this. I can go the long route and hide windows via the wiki. Was looking for an easier route tho...
-HarumaN
