Author Topic: Wii Modhcip question, GC2-D2E with black glue, anyone here mod that? (solved)  (Read 8805 times)
spystyle
  • Thanks alot, now I have to build a time machine and warn myself yesterday!
  • Last login:February 23, 2021, 02:30:18 pm
Hello from Maine,
An acquaintance of mine has the Wii with the black glue on the chip, full details here :
http://www.wiidrives.com/identify?serial=LU64126327
It's the "GC2-D2E" covered in black glue.
She wants me to mod it for her. Have any of you modded this one?
I haven't modded a Wii since 2007 back when it was only 6 wires
Craig
« Last Edit: February 19, 2010, 04:20:32 pm by spystyle »
Ginsu Victim
  • Comanche, OK -- USA
Just softmod it.
spystyle
Thanks for chiming in :)
I don't know a thing about soft-modding a Wii. What method do you successfully use?
And with that would they have to avoid updates? If so is it a big problem if they accidentally install an update? Would it result in a  bricked Wii?
I'd like to set it up so it's idiot-proof as I won't be there and they aren't techno-savvy.
I'm under the impression that a hard-modded Wii is unlikely to get bricked ...
« Last Edit: December 30, 2009, 01:38:31 pm by spystyle »
You can't ever guarantee a modded device won't get bricked by an update, hard or soft modded.  It's a risk we all take.
If you look in the Wii USB hard drive thread here there is a lot of good info on soft mods and things we ran into doing it.  That's probably your best end goal - a 250-320gb hard drive to load from.  The loaders are being coded to work around stuff like required updates and security tweaks.
spystyle
I like the idea of using a USB hard drive rather than DVD-R's ... Maybe I should just send over our hard-modded Wii and set theirs up to use USB for my daughter and I :)
Is it easy to do or a terrible pain in the butt?
Hoopz
  • Last login:June 13, 2025, 09:18:32 pm
  • Intellivision Rocks!
The soft mod takes about 20-30 minutes and that includes reading/prep time.  It's easier than modding an Xbox.
spystyle
Sweet :) I happen to have a 30 minute attention span  :P
OK I'll check it out  ;)
Took me about 5 days (an hour or two a day) to get the softmods all in and working.  Note that I have a good amount of experience modding Tivos, consoles, etc.
Ginsu Victim
Took me a few hours of running back and forth, reading a guide, copying files, etc
It can be done quickly once you know what you're doing, but the first time takes a little while.
Priiloader will block a disk from updating, and it also blocks online updates. Just have to use the settings in the hacks.ini file.
spystyle
OK, when I first started this thread I also sent out a few e-mails, I just got one reply :
I asked...
Sales(at)modchip-depot(dot)com
...and they said this one is super easy to install and works on said Wii :
http://tinyurl.com/ykwl75k
"DriveKey 2.0"
Have any of you tried "DriveKey 2.0" ?
« Last Edit: January 01, 2010, 10:52:39 am by spystyle »
Hoagie_one
  • Um....whats a cabinet
I just installed a drivekey for a guy on the boards here.  It was super easy.
spystyle
Sweet :)
"Super easy" happens to be the way I like it !
« Last Edit: January 01, 2010, 10:51:23 am by spystyle »
Ginsu Victim
Yeah, I read that DriveKey was best for the black glue problem.
hypernova
  • Last login:November 25, 2016, 12:52:48 pm
Softmodding is so easy it makes you wonder why everyone doesn't do it after they learn about it.  With it, I don't quite understand what the necessity of a modchip is for a Wii.
I'll exercise patience when you stop exercising stupidity.
My zazzle page.  I've created T-shirts!
spystyle
It probably dates back to the days of "Playstation"
I think it was about 13 years ago.
"Modchips" came out of Hong Kong, they were so amazing, it changed everything! Now every game rented could be copied :)
It was like 6 wires to solder, the chip looked like a spider. It was so cool :)
It was CD-R disks burned at 2X on a Pentium 2 computer if I recall.
Since then we've come to trust a hardware modification.
We just don't have the same level of faith in software mods - they seem less effective.
It seems like a software mod could be killed by a software update, but a hardware mod seems more resilient and cooler.
We'll see - by the time the Wii is "old" we'll look back and see if there was any point to hardware mods or not :)
Hardware modding seems so straight forward too - you open the console up and add a piece - that's it.
With software mods it seems so much more complicated...
Ultimately though I just love modchips :) They are so cool
« Last Edit: January 01, 2010, 04:05:17 pm by spystyle »
DrumAnBass
  • Last login:July 10, 2024, 10:36:54 pm
  • "I love this computer magic!" - Viv Savage
I have a DriveKey on my WII and it works great. Love it.
However - a word of caution -  I installed one on my in-laws WII and theirs didn't work. Very frustrating. Seems like there may be some WII consoles that the DriveKey doesn't like...
I suppose you want to make sure you get a 2.0 version of the DriveKey - maybe they have rectified the problem, as I the one I put in my in-laws console was a 1.1 version I believe.
"Some drink from the fountain of knowledge; I only gargle."
spystyle
Thanks, will do :)
http://forums.afterdawn.com/t.cfm/f-154/4_1_and_below_firmware_softmod_guide-all_systems_except_for_korean_linked_4_2_guide-797772/
took about 2 hours. granted everything was just "follow this guide and it'll work" and so far it has. It IS scary reading the brick warning the first 6 or 7 times
Ginsu Victim
Malenko:
Just make sure you install priiloader. It will prevent updates and help you recover from a brick (helped me recover once already).
Malenko:
Linky stinky?
Also, just for the record, that wasnt a dig at Chad, just saying the software and guides out there now are freekin amazing.
Ginsu Victim
www.wiihacks.com
Search for priiloader in thread titles.
SNAAKE
  • Trade Count: (+29)
  • Last login:October 08, 2025, 05:48:43 pm
  • my joystick is bigger than your joystick !
Re: Wii Modhcip question, GC2-D2E with black glue, has anyone here modded that?
« Reply #21 on: February 14, 2010, 09:48:26 pm »
get a wiikey2? those are easy to install(assuming you can solder in tiny points). no cutting ic chips or any other monkey business involved. just plain old soldering. get the yellow sticker though. I forgot but I think its only like 6 or 7 wires. I remember doing a few. took me less than half hour.
also whats this "brick protection" I hear about for wii softmods??
spystyle
« Reply #22 on: February 15, 2010, 12:19:55 am »
On the topic of hardware mods versus software mods -
I'd like to get an unbiased opinion from someone who has done many software and hardware mods - I suspect the biggest softmod advocates don't actually own soldering irons and the biggest hardmod advocates (like myself) think that software if voodoo.
Apparently they are both pay services, my friend Ryan was telling me that a kid was trying to charge him $25 for information to perform a softmod on his Wii (Ryan would actually have to do it, the kid was just going to send him a zip file or something)
$25 ? That's the price of a WiiKey !
 :burgerking:
« Reply #23 on: February 15, 2010, 08:27:14 am »
Ive done both, I used to put modchips in PSX and XBOX. Most PSX chips used 6 to 8 wires, and when I first did XBOXs they used 56? solder points (half on chip, half on board)
then I used to do TSop flashes on xbox, then moved up to softmods when the 1.6s came out. Now I still do CFW flashes on PSP, DVD firmware flashes on 360,and I do softmods on Wii. I still own a soldering iron.
Ginsu Victim
« Reply #24 on: February 15, 2010, 10:09:08 am »
I've installed modchips in several Playstations in the past, but have my XBOX, Playstation2, and Wii softmodded. The PS2 softmod has worked fine for many years, the XBOX I've had softmodded for a year without issue, and the Wii is "so far, so good".
This is an arcade forum. You've gotta have a soldering iron and know how to use it in this hobby.
Ed_McCarron
« Reply #25 on: February 17, 2010, 10:56:14 am »
Theres a distinct difference between being able to recap a monitor and soldering chip legs that are so small you need to isolate them with razor blades to keep from hitting adjacent legs.
I can chip an xbox in my sleep.  My PS/2?  Damn near killed me.
I'm a hardware guy.  I settled on the softmod for the Wii because it was so darn easy.
spystyle
« Reply #26 on: February 17, 2010, 12:36:47 pm »
I agree the old Playstation 2 mods were terrible!
Apparently the new ones are solder-free
spystyle
spystyle
« Reply #28 on: February 17, 2010, 04:21:08 pm »
Ignore the spelling-police? OK, but it's unwise  :burgerking:
I try in vain to pretext and serve ...
spystyle
« Reply #29 on: February 18, 2010, 09:42:25 pm »
OK, I just installed a DriveKey, it was super easy.
Here is a pic :
After that I covered it in electrical tape and reassembled the Wii, it works fine and it's a done deal :)
Just to explain to anyone who has not modded a Wii :
The driveKey is relatively expensive but very easy to install, all you need is the tri-wing and phillips-head screwdrivers that can be ordered with the chip, and electrical tape. There is absolutely no soldering involved.
It is super easy as long as you have a well lit work area, peace and quiet, and take your time.
Follow this guide to dismantle the Wii :
http://wiki.nintendo-scene.com/Wii_disassembly
And whatever guide corresponds to your DriveKey, I had the DriveKey2 and used this guide :
https://modchip-depot.com/faq.php?CDpath=0&cID=2#4
As you can see the DriveKey is simply plugged in-line from the mainboard to the DVD drive, and that's all there is to it!
Also my other pal wanted a mod on the cheap, actually for free, I had an extra WiiKey1 I had forgotten about, so here's some small scale soldering :
I used my new-fangled soldering iron :
http://www.curiousinventor.com/store/product/254
It's pretty cool :)
I used 30 gauge wire, stripped and tinned, and a little flux on all mating surfaces prior to soldering them. I had forgotten how small those solder points on the WiiKey are! They are small like the letters on a penny.
Have fun!
Craig
« Last Edit: February 19, 2010, 07:34:33 pm by spystyle »
« Reply #30 on: February 19, 2010, 01:18:29 pm »
Guess again, chuckles.
http://www.google.com/search?hl=en&source=hp&q=ps%2F2&gbv=2&oq=&ie=UTF-8&sa=N&tab=iw
I clicked, youre still wrong. a PS/2 is a plug for a keyboard and a PS2 is a playstation 2.Just because the first result was sony's website doesnt mean that PS/2 is right, the second result is "keyboard connector"
http://en.wikipedia.org/wiki/PS/2_connector
http://en.wikipedia.org/wiki/Playstation_2
1987 trumpts 2000
http://en.wikipedia.org/wiki/PS2_(disambiguation)
move along, nothing to see here
spystyle
Yeah I was just fooling around, being "spelling police" is never productive :)
Anyway, soldering is fun :) But I can't play NSMB on my WiiKey1 straight, apparently I have to use the USB-loader, so I'll have to study that.
I also have a swap-disk on my PS2 and didn't even realize they made a soft-mod for that, I might look into that but I bet I'll find it voodoo-like and end up ordering a solder-free PS2 mod-chip. The swap disk is cool but I find it irritating.
Cheers
Craig
:burgerking:
Hoagie_one
I used to make the mod memory cards for the ps2.  They work great.
spystyle
Tell me more, I've never heard of that :)
Nipedley
  • Last login:October 04, 2024, 12:03:26 am
I installed my Wiikey when they first came out, but got into the softmod thing a little while ago as well. They both have their uses, the wiikey is definately best in my opinion for copying a game onto a disc and playing it, while softmod is great for playing games on usb/homebrew. I don't use homebrew often, usb loader is good, but I still prefer to have everything on disc just in case.
That said, my PS2 is softmod as I couldn't get hold of any hardware mods at the time and I wouldn't really want to now - the hdloader is fantastic.
Essentially then, it's all down to personal preferences :dunno
