Author Topic: WG D9800 & Ultimarc ArcadeVGA2 (PCIe) H-Size problem  (Read 1988 times)
ei8ht
  • Last login:January 02, 2023, 03:20:47 am
« on: December 25, 2009, 06:30:52 am »
Hello guys,
I'm using a ArcadeVGA2 (driver used which were delivered with the card) on a WG D9800 /Win7 64bit. My frontend is MameUI64 0.135u4. I've already set all game infs with avres. My problem is that I have to make the picture smaller but the menu point h-size on my OSD says already "0". I am not able to adjust the picture over the CCC, because the button is grayed out.
I am not sure if the hardware could be broken. On the boot screen I have between the written text white stripes and geometry probs with my wg with a resolution 800x600 on the right site (no way to make it almost perfect with OSD).
Does anyone have an idea, what I can try to solve that problem?
By the way...merry x mas  :)
MrMikeZH
  • Last login:March 21, 2021, 04:41:43 pm
Re: WG D9800 & Ultimarc ArcadeVGA2 (PCIe) H-Size problem
« Reply #1 on: December 25, 2009, 11:59:24 am »
on the chassis you can find a h-size analogue pot. use that to shrink the picture just to fit, if you shrink it too much you will get sidecompression on 15khz modes.
ei8ht
« Reply #2 on: December 30, 2009, 09:16:46 am »
Thank you for your reply.
I used the analog pot, but It won't go small enough to fit.
Any other idea?
 :hissy:
Edit: Added some pictures, so you guys can see what I am talking about.
« Last Edit: January 03, 2010, 08:01:29 am by ei8ht »
ei8ht
« Reply #3 on: January 07, 2010, 01:01:45 am »
I solved the problem!
The eeprom on the chasis was the reason for it. After reading out a working eeprom and overwriting my old one it worked fine...
Maybe that helps other with the same problem in the future...
