Author Topic: Christmas is tomorow HELP. EMS Topgun 2. $10 paypal for the fix.  (Read 1728 times)
P Del Castro
  • Last login:April 28, 2010, 12:35:04 am
« on: December 24, 2009, 07:37:12 pm »
I hooked up two EMS Topgun II without a hitch using the latest drivers to an Xp sp3 Pc.They where working on pc games and model 2. Then I decided I would mess with the button configuration because I wanted reload to go to the trigger on the grip instead of the side. Then all the sudden they started acting as if they were the same gun. They are tracking two separate pointers but both guns fire gun 1. I uninstalled the drivers in device manager and switched usb plugs. Reinstalled many times but the problem wont go away. If anyone can help I will send you $10.00 via paypal to get me outta this bind before tomorrow.
TheSlim
  • Last login:September 27, 2015, 10:11:37 am
Re: Christmas is tomorow HELP. EMS Topgun 2. $10 paypal for the fix.
« Reply #1 on: December 28, 2009, 11:05:47 am »
This is probably too late.  But here are a few suggestions:
Try switching to smog's drivers and use the troubleshooter program (http://thetroubleshooter.home.mindspring.com/).  Smog's drivers can be found on google.
If you want to switch drivers to smog's you need to go to the device manager and then click "update driver" for the EMS topgun II, then you click have disk and then point to Smog's drivers.
OR you can try my method if you are using EMS's drivers.  This is what I have to do to get it working.  I have the 64bit drivers, from EMS forums, which I updated a little (BTW my machine with the topguns is for sale in the B/S/T forum).  I find it easier to start the machine with no guns plugged in, then I add one gun allow the system a few seconds to recognize it, then I make sure it is working and I add the second gun.  This might be a pain, but for me it is the easiest way to get both guns working.  I generally just need one gun so I just keep the one gun plugged in all the time.
Hope that helps :)
