Author Topic: Indy 500 twin arcade - missing background during play - Please help!  (Read 1737 times)
Irish2010
  • Last login:February 24, 2010, 07:08:41 pm
I have an Indy 500 twin arcade and on one of the screens I can't see the background during play.  All I see is a blue screen with the controls(speed, time left to play).  Anyone have any idea what is causing this?
grantspain
Re: Indy 500 twin arcade - missing background during play - Please help!
« Reply #1 on: December 22, 2009, 06:27:15 am »
 video board on the model 2 stack,common problem-most likely to be a bad solder
Irish2010
« Reply #2 on: December 22, 2009, 10:26:03 am »
Thanks for the info.  I will check that out when i get home.
grantspain
« Reply #3 on: December 22, 2009, 02:06:05 pm »
the problemis with the large surface mount ic's and rams,not something you can fix with a standard soldering iron-you will need suface mount technology
try reseating the pcb stack first
Irish2010
« Reply #4 on: December 22, 2009, 06:29:33 pm »
I opened each game up and noticed that the game not working has a blicking red light on the board.  The other car that is working has a green light.  Is ther any way to know the error based on the lights.  It liooks like it is a block of 6 lights.
grantspain
« Reply #5 on: December 23, 2009, 04:37:17 am »
I can't remember what that ponits too,I am pretty sure its either a low +5 or an ic error
try contacting  http://www.andygeezerservices.co.uk/
if anyone knows the fault this fella will
i am sure this is a video board problem though-very similar to what you see on daytona
Irish2010
« Reply #6 on: December 28, 2009, 04:05:25 pm »
Thanks Grant.
