Author Topic: ArcadeVGA Problems - 200Hz - Poor windows picture  (Read 1384 times)
rezero
  • Last login:February 06, 2010, 11:07:20 pm
« on: December 14, 2009, 08:46:39 pm »
I have the ArcadeVGA card that I purchased a long time ago, and am just now getting around to installing due to overseas travel and a job change.  I followed everything on the instructions on the website, and think everything went pretty well.  The two questions I have are that my Systems/Device Manager is now showing 2 video cards.  One says Ultimarc…  and the Other says Secondary R9250…  They both have the same drivers.  When I go to the display settings, my computer is using the Ultimarc one with it set in 32bit mode, but when I look at the monitor it is reading a frequency of 200Hz.  The Secondary R9250 one is not being used but will not switch above 8-bit mode.  When I select 32-bit it defaults back to 8-Bit.  The screen looks okay in Mala, and on most games, but very poor in windows.  The screen is blurry and shakes and has speaker feedback in windows.  Since I do not have any experience with the card is this normal (the 200 Hz frequency and issues with windows).
My card is an AGP ATI R9250 series with a single VGA output.  I am running Mala/Mamegui combo.  I am not sure of my monitor but it is from a Mortal Kombat Machine with a standard 15khz-60khz monitor (the chassis says Wells Gardner 25k7193).
Lastly, I made my own connector from the arcadevga and the chassis.  The color and ground wires were obvious, but I put one wire to the –vSync and –Hsync instead of putting them both to the –hsync.
Any help would be appricated.
Tony
dekar24k
  • Last login:April 28, 2019, 03:50:11 pm
    • ArcadeForum.com
Re: ArcadeVGA Problems - 200Hz - Poor windows picture
« Reply #1 on: December 19, 2009, 04:50:55 am »
Did you try the TriSync util from Ultimarc?
http://ultimarc.com/AVGA_TriSync.exe
Finished project: "The Saloon Arcade" - 2 player upright cabinet
Joystick.net - Retro gaming news and reviews
