Author Topic: Quick and Easy Crossover Cable...  (Read 1763 times)
  • Last login:July 23, 2025, 07:04:20 pm
« on: December 11, 2009, 01:54:36 pm »
Can't I just take a normal Cat5e ethernet cable, cut it in half, and rearrange some of the wires?  I recall someone doing this, but I can't find it anywhere...
JMB
  • Last login:July 20, 2023, 07:29:22 pm
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:October 17, 2025, 07:04:22 am
Re: Quick and Easy Crossover Cable...
« Reply #2 on: December 11, 2009, 01:57:18 pm »
No nononono don't cut it in half. Blecho. Bad. You *can* cut the end and reterminate the end to make a cross over cable, but don't snip it in half and twist tie or electrical tape the wires together. Not if you actually want to get any kind of reliable data across the cable.
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
« Reply #3 on: December 11, 2009, 02:03:15 pm »
I don't have the tools to terminate the ends, but I do have plenty of normal cables on hand...
  I was planning on soldering and shrink-tubing the wires (check my custom title ;)).
Zero_Hour
  • Last login:August 07, 2024, 11:40:33 am
  • Enjoying the irony of taking games seriously
« Reply #4 on: December 11, 2009, 02:09:52 pm »
Frys and the like should have RJ-45 connectors that don't require tools to crimp. I've used them before with no problems. I'm sure you already have wire strippers which is the only other thing you should need. You are definitely making more work than you need to if you go the soldering route. Besides, the solder point will still be a weak spot if there's any flex in the cable.
"Paradise, is exactly like where you are right now - only much, MUCH better." -Laurie Anderson
« Reply #5 on: December 11, 2009, 02:11:24 pm »
Boo... all you people raining on my parade...  I guess I'll be stopping by Fry's on my way home...  :D
Zero_Hour
« Reply #6 on: December 11, 2009, 02:14:35 pm »
Don't sweat it man, your reign as Solder :burgerking: should continue without issue.
« Reply #7 on: December 11, 2009, 02:18:18 pm »
You don't want to try soldering all of the wires inside a cat5e sheath.  You just don't.  Buy a $10 crimper and put a new end on.  You'll be really glad you did.  Even for a strong solderer you're talking 5x the amount of work of cutting and recrimping.
« Last Edit: December 11, 2009, 02:20:44 pm by ChadTower »
JMB
« Reply #8 on: December 11, 2009, 02:26:21 pm »
I've one seen tool free keystone jacks? Is there something else? Probably be cheaper just to buy a crossover cable.
saint
« Reply #9 on: December 11, 2009, 02:33:36 pm »
Ethernet's not like farming cattle boy (or some other StarWars quote mangle). I wouldn't do it. Let us know how that works out :)
(saint is a network engineer)
--- John St.Clair
     Project Arcade 2!
Zero_Hour
« Reply #10 on: December 11, 2009, 02:53:06 pm »
I used a slightly different (cheaper looking) type, but here they are:
http://southernhillscomputer.com/rjcautptopl.html
Ed_McCarron
« Reply #11 on: December 11, 2009, 04:19:45 pm »
Yes.  You can, but it'll work like sheeeit.
For 10 meg, just swap the orange and green pairs - IF its a standard 568B cable.
Even cheapo leviton jacks like HD carries can be terminated with the stuffer cap it comes with.
Saint - in an emergency, I've had customers ask me to splice Cat5E cable -- which I've done by soldering -- preserve the pairing and twist count, and 9 out of 10 will still pass testing at 100M speeds.  So sayeth my Pentascanner.
saint
« Reply #12 on: December 11, 2009, 04:26:24 pm »
Yeesh. I believe it, but it still gives me the willies.  ;D
--- John St.Clair
     Project Arcade 2!
Vanguard
  • The aliens are using their mouthpiece, "Saint" to discredit my theory.
  • Last login:October 31, 2025, 09:18:32 pm
« Reply #13 on: December 11, 2009, 04:35:01 pm »
I thought you guys only know how to break networks.   I didn't know you knew how to fix them.
J_K_M_A_N
« Reply #14 on: December 11, 2009, 04:40:48 pm »
http://www.littlewhitedog.com/content-8.html
I've always used the following for a regular cable:
Orange/White - Orange - Green/White - Blue - Blue/White - Green - Brown/White - Brown
I use that on both sides and it works fine. Is that not the way to do it now a days? I would hate to have to re-memorize a new layout. :) (But I would like to make them right)
J_K_M_A_N
testicle187
  • Last login:April 10, 2025, 05:29:07 pm
« Reply #15 on: December 11, 2009, 05:53:48 pm »
J_K_M_A_N
That is standard 568b wiring for a straight through patch cable.  That is what you want.  If you wanted a crossover you would want this:
saint
« Reply #16 on: December 11, 2009, 06:11:58 pm »
Breaking them is what we do for fun when we're bored so we can then come in and "fix" them and convince you how indispensable we are.  ;D
--- John St.Clair
     Project Arcade 2!
dafelandry
  • Last login:March 21, 2012, 12:08:40 pm
