Author Topic: Looking for Piano hinges...  (Read 1725 times)
Justin
  • Last login:November 25, 2025, 10:20:05 pm
    • Centipede MAME cabinet
« on: July 20, 2003, 10:51:29 pm »
I'm looking for a 20-22" piano hinge to attach my control panel to the cab.  I only find 10" and 30" hinges at Lowes and HomeDepot.   Can I cut a 30" hinge? Or will the inner axis fall off?  These only come in brass, AFAIK... can I spray paint without chipping or sticking?
Anyhow, if you know of a good source forvariety of piano hinges, please let me know.
"3 warps to Uranus" -- so I stopped playing!
AlanS17
    • AlanS17
Re:Looking for Piano hinges...
« Reply #1 on: July 20, 2003, 11:01:31 pm »
I cut it with my jigsaw and a metal-cutting blade. I'm sure it can be done wit a hacksaw, too. My recommendation for keeping it straight while cutting would be to screw it down to a piece of wood either flat or along an edge and just saw the whole thing. That's what I did and it worked great.
vusteveii
  • Last login:July 07, 2003, 09:26:47 am
« Reply #2 on: July 20, 2003, 11:08:39 pm »
Have you thought about using 2 10" ones?  That seems like the easiest solution, the lowes in nebraska has silver ones.
steve
Justin
« Reply #3 on: July 20, 2003, 11:41:49 pm »
I also have the original control panel's hinge (centipede, heavy duty, black).
The hinge is glued to the panel... does anyone have any idea how t remove this thing from the panel?    (FYI, the panel itself is a total loss).
Bluntman
  • Last login:September 28, 2006, 04:50:13 am
  • RTFM, failing that, kick it.
    • Bluntmation
« Reply #4 on: July 21, 2003, 06:48:58 am »
I cut the piano honge that I used on my CP with snips (I have a strong grip) no problem... give the cut end a but of a sand though... really sharp edge.
Hell hath no fury like a woman scorned for Sega.
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #5 on: July 21, 2003, 12:07:44 pm »
Justin
« Reply #6 on: July 23, 2003, 08:09:48 pm »
Can anyone think of a way to detach the original hingre from the metal control panel?  it is stuck with glue.  A very strong bond.  Maybe some solvent?    I just want to make sure I don't end up removing paint from the black hinge -- it is in perfect condition.
BobA
  • What Me Worry?
« Reply #7 on: July 23, 2003, 11:45:53 pm »
Are you sure it is glued?  Most are spot welded to metal control panels.
BobA
pmc
  • Last login:December 20, 2023, 07:43:02 am
    • website
« Reply #8 on: July 24, 2003, 01:13:43 am »
I used two shorter hinges (2x12 I think) and it came out great.
Justin
« Reply #9 on: July 24, 2003, 07:56:16 am »
BobA
Sure LOOKS like glue to me.  I even pried one end off (about 1/2 inch to verify.  I don't want to continue separating it that way, because it bends the hinge...
