Author Topic: Questions - IPAC/MiniPac wiring, U360 issue, and pinball  (Read 2132 times)
spOOf
  • Last login:March 27, 2010, 04:36:21 pm
« on: November 25, 2009, 10:34:36 am »
Hey gang,
My cabinet is really coming along, thanks to much help here and by trusty Project Arcade book.  I have a few questions as I wire up my control panel...
1. I have an 8-button layout and a minipac.  What is the optimal way to wire this.  I started doing it and then tried playing Street Fighter.  My buttons seemed off.  Could someone matchup the standard switch(SW) wiring pattern for me?  I went top - 1,2,3,4 & bottom 5,6,7,8 - but that seems wrong. Should it go top odds, bottom evens?  Maybe 1237, 4568?
TopRed SW1
TopYellow ?
TopGreen ?
TopBlue ?
BotRed ?
BotYellow ?
BotGreen ?
BotBlue ?
2. I swapped in the long handle for my U360, attached to panel and plugged it in.  When I started playing, I'm off 90 degrees (up moves right, right moves down, etc).  Did I screw up here?  If so, what's the best way to fix it.
I haven't wired anything for player 2 yet, waiting until I get player 1 right (and some parts come in).
3. How do you guys wire up your pinball buttons?  I currently will just have right/left flipper and right/left nudge.
Thanks for the assist!
My project: The Royal Flush
Ginsu Victim
  • Last login:May 19, 2026, 02:16:47 am
  • Comanche, OK -- USA
Re: Questions - IPAC/MiniPac wiring, U360 issue, and pinball
« Reply #1 on: November 25, 2009, 10:50:20 am »
Yeah, I'd say
1237
4568
You can just reattach the PCB to face the correct direction.
Check out my first product, The Tone Ledger, a premium workflow tool designed for guitarists, bassists, keyboardists...pretty much anyone who enjoys using amps and pedals.
