Author Topic: Nintendo Sanyo Color Problem  (Read 1207 times)
Auric
  • Last login:November 23, 2015, 03:16:52 pm
  • Greetings Programs!
    • Aurcade.com
« on: November 06, 2009, 10:23:30 pm »
I've got a Nintendo Sanyo EZ monitor that is from my Cyberball cab. The display is washed out pink. Meaning a solid wash of pink across the screen. I still have an image and still seem to have blue and red (though as stated, washed out badly).
I did some testing and can confirm the Green seems to be missing (which with an inverted signal is causing the wash out). So what part of the board would be the culprit? What should I look for to replace?
I've already swapped the transistors for Green and Red on the board just to see if that was it, and it produced no different results.
Yelp!
I drank WHAT!?!?! - Socrates
Aurcade.com - Find The Coin-op Games You Want To Play!
