Author Topic: help with ipac? (shift)  (Read 1285 times)
izzmd1992
  • Last login:November 17, 2009, 07:36:42 pm
  • Dont be bringin that britney spears ---steaming pile of meadow muffin---.
« on: November 04, 2009, 09:34:52 pm »
I have the ipac2, and wired all of my cp to it. All seems to be working except for the shift function. I downloaded winpac to check the settings, and saw that shift was programmed to a button i didnt have, 1p-a, i changed it to 2p-2start button, but its still not working, any ideas?? thx
surface tension
  • Last login:July 01, 2018, 08:45:48 am
  • feel the tension...
    • surface tension tables
Re: help with ipac? (shift)
« Reply #1 on: November 05, 2009, 08:06:11 am »
First thing to try... after programming the ipac, have you checked to see it works within winipac? You can see this from the table or shifted mode display.
izzmd1992
« Reply #2 on: November 05, 2009, 09:53:32 pm »
Hey guys, after some trial and error got this working well, thanks.
and thanks to St, test mode helped  ;D
