Author Topic: Will most 27" crt diag. fit inside 26" wide decased?  (Read 1232 times)
KapnKerfuffle
  • Last login:November 23, 2016, 11:48:14 pm
« on: November 02, 2009, 07:15:34 pm »
I'm on the hunt for a 27" or 25" TV to replace the "small" 20" computer monitor in my cab (doesn't feel small when I lift it >.<) .  My cabinet is pretty much the default dimensions found in John St. Clair's book.  The opening is 26" wide exactly.
If I yank the case off, will most 27" TVs fit?
Think the Unthinkable, Know the Unknowable,
Screw the Inscrutable and Eff the Ineffable.
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
Re: Will most 27" crt diag. fit inside 26" wide decased?
« Reply #1 on: November 02, 2009, 07:30:29 pm »
I am not sure if this will help, but please check out the dimensions as follows http://niemandisplays.com/monitor%20mechanical%20dims.pdf
These are the dimensions for our open frame monitors and dimension "A" should be close even on a decased TV.
Hope it helps!!
Rick@Niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
KapnKerfuffle
« Reply #2 on: November 04, 2009, 11:00:08 am »
Thanks Rick!  That helps a lot.  Looks like it might be a squeaker!  I can't believe CRT's are getting so hard to find.  25" with s-video would be perfect, but I can't find one.
