Author Topic: Projects for Sale in Houston, Tx  (Read 1958 times)
whoamonga
  • Last login:June 04, 2025, 09:24:09 pm
« on: November 02, 2009, 01:13:51 pm »
Hi,
Need to lose a little bit of weight...
I have a Time Killers machine in a Data East cab that works with everything but sound.  Needs a 4-pin molex to connect speakers to on-board connector instead of through the harness.  $150
Got a partially working Dig Dug cabinet in rough shape.  The bottom 6" of the cab on one side is brittled away, so the cabinet leans.  Also, the screen is jumbled.  Could be monitor, but i think the board was tested non-working when i traded for it, so that might be it.  $75.  Worth that for the parts...
Pigskin 621 a.d. works all the way but missing 1st player 49-way joystick.  This midway mono board setup runs perfect.  It's a conversion cab form what i think is an old taito cabinet.  original marquee and plays otherwise...  I have the joystick, but the ball broke off and i took it off intending to fix it. $50
Also a fully working Top Gunner from a converted Super Cobra cabinet.  Re-capped monitor.  $175.
Variety of WG4600 and 4900s with problems.  $15 each.  Come with brackets, boards, tubes, everything complete.
Variety of coin doors and buckets. $5
Will try to get some pictures up tonight.  If you have any questions, let me know.
Thanks much!
SlayerAlex
  • Last login:September 17, 2011, 09:19:27 pm
Re: Projects for Sale in Houston, Tx
« Reply #1 on: November 03, 2009, 05:48:46 am »
yeah some pictures would be good. and as for coin doors, you wouldnt happen to have any 4 player ones would you?
whoamonga
« Reply #2 on: November 03, 2009, 10:04:56 am »
whoamonga
« Reply #3 on: November 04, 2009, 01:38:34 pm »
put some more pics up on the 2nd link
Drews Arcade
  • Last login:July 28, 2018, 01:15:02 am
« Reply #4 on: December 18, 2009, 08:26:58 pm »
Looks like you have some midway coin doors, do you still got them? If so, one is sold to me, email me.
