Author Topic: How to combine XBOX360 with Ipac  (Read 2183 times)
Donpatchi
  • Last login:May 17, 2015, 04:09:28 pm
« on: October 21, 2009, 05:20:05 pm »
Hello,
I am currently building an arcade cabinet. I kinda wondered about the following.
I would like to have a cab that runs both mame and an XBOX360. So to make it simple I have a button connected to the IPAC how do I also connect it to a hacked XBOX pad? Do I just bridge it to the pad? or is it necesary to used diodes or switches or whatever? Schematics would be uber :D
fallacy
  • Last login:February 19, 2026, 07:24:28 pm
Re: How to combine XBOX360 with Ipac
« Reply #1 on: November 08, 2009, 08:42:05 pm »
I don’t know I could not get it to work right. :timebomb: If you use a Max Shooter you can get Player 1 to work with the 360. http://www.imarketcity.com/maxshforxb36.html
sju4sju
  • Last login:March 16, 2010, 12:22:57 pm
« Reply #2 on: November 09, 2009, 10:03:32 am »
Just drop the IPAC and use only the hacked 360 controller, it'll work on both 360 and PC.
fallacy
« Reply #3 on: November 09, 2009, 09:53:41 pm »
Hows that ???
  • Last login:Yesterday at 01:44:17 pm
« Reply #4 on: November 10, 2009, 01:08:46 pm »
Hows that ???
You can plug an Xbox 360 controller into a PC and it recognizes it as a joystick.
fallacy
« Reply #5 on: November 11, 2009, 01:48:55 am »
Doesn’t MAME need a keyboard? If not mame will recognize 2 regular xbox360 controllers?
« Reply #6 on: November 11, 2009, 06:29:30 am »
1) No
2) Yes, as Joy1 and Joy2
You need to enable joystick support... or setup Joy2Key.  Either way will work.
