Author Topic: Easiest fe?  (Read 4195 times)
jeremymil
  • Last login:August 30, 2012, 11:16:49 am
Easiest fe?
« on: October 20, 2009, 12:24:19 pm »
Please don't say Mame32 or UI,  I see that hyperspin seams to be the fav in the poll, How does it compare to Mala for simplicity?
abispac
  • Last login:Yesterday at 10:13:01 pm
Re: Easiest fe?
« Reply #1 on: October 20, 2009, 04:45:35 pm »
mala its easy to setu up, but hyperspin looks way better, once you start gettin in the hyperspin fe its easy to setup too.
youki
  • Atomic Front End Creator
    • Atomic Front End
Re: Easiest fe?
« Reply #2 on: October 20, 2009, 05:02:57 pm »
You can try AtomicFE , now with AtomicStudio it is quite easy to setup.  At least for "standard" usage.
here a tutorial :
http://www.atomicfe.com/EN2/doc/English/index.html
Cakemeister
  • Last login:May 31, 2024, 06:23:16 pm
Re: Easiest fe?
« Reply #3 on: October 20, 2009, 08:49:06 pm »
Maximo G+ pretty much sets itself up.
Old, but not obsolete.
Kordova
  • Last login:June 25, 2013, 06:30:42 pm
  • Lawyered...
Re: Easiest fe?
« Reply #4 on: October 21, 2009, 12:36:35 am »
I really like GameEx.  I have been using it for over year now.
speedklz
  • Last login:November 17, 2018, 12:56:23 pm
Re: Easiest fe?
« Reply #5 on: October 21, 2009, 10:26:13 am »
I googled  maximo G+ and I see references to it but no link for it..
Best of the Best of the Best. Sir!
jeremymil
Re: Easiest fe?
« Reply #6 on: October 21, 2009, 01:21:44 pm »
I think i am going to use Mala it seems the most simple.
speedklz
Re: Easiest fe?
« Reply #7 on: October 21, 2009, 02:14:45 pm »
Never mind my question, I found it. Its callem maximus arcade
Cakemeister
Re: Easiest fe?
« Reply #8 on: October 21, 2009, 02:24:21 pm »
Actually, Maximo G+ and Maximus are two different applications.
IG-88
Re: Easiest fe?
« Reply #9 on: October 21, 2009, 02:28:17 pm »
I love Maximo G+. It has worked on every system I've tried.  :cheers:
-HarumaN
headkaze
  • 0x2b|~0x2b?
Re: Easiest fe?
« Reply #10 on: October 21, 2009, 03:25:36 pm »
That totally backfired on you this time Cake :laugh2:
speedklz
Re: Easiest fe?
« Reply #11 on: October 21, 2009, 03:59:58 pm »
Well, I cant seem to find maximo, the only thing I did find says it is the same as maximus arcade. So back to the question Is there a link to maximo..
« Last Edit: October 21, 2009, 04:01:33 pm by speedklz »
jeremymil
Re: Easiest fe?
« Reply #12 on: October 21, 2009, 04:09:11 pm »
So I think that i am gonna use mala or atomic, I want, videos from emumovies, adult filtering, and ease of use, hyperspin looks busy, so what should i use?
youki
    • Atomic Front End
Re: Easiest fe?
« Reply #13 on: October 21, 2009, 04:11:46 pm »
Try both.  and choose the one you prefer.
dafelandry
  • Last login:March 21, 2012, 12:08:40 pm
Re: Easiest fe?
« Reply #14 on: October 21, 2009, 06:22:22 pm »
Youki AtomicFE rules (thanks)!!! Plug n play mods kick ass!! I would recommend it 100% and make sure u read the tutorial and its straight forward from there... easy to customize, uses low resources and no problems!! great for an old P4 pc!!!
youki
    • Atomic Front End
Re: Easiest fe?
« Reply #15 on: October 22, 2009, 04:27:20 am »
Thanks.
Concerning plug'n play modules. The ones visible on my website are more the 'old generation'.
We have now hundreds of "new generation" modules here
http://www.atomicfe.com/ladite/arcade01_en.htm
That is not straight forward to find this link on my website  :-[ (the website will be redone completly with the next release)
speedklz
Re: Easiest fe?
« Reply #16 on: October 22, 2009, 09:46:03 pm »
SO how about a link to Maximo. I would like to get a look at it.
Cakemeister
Re: Easiest fe?
« Reply #17 on: October 23, 2009, 12:04:29 am »
Hmmmm. The farce is strong in this one.  ;D
protokatie
Re: Easiest fe?
« Reply #18 on: October 23, 2009, 02:57:52 am »
Personally I would recommend AtomicFE .19. I didn't care for .20 at all tho... I just hope that Youki will still give support for version .19 in the future. (and maybe post my front end on his site...... ... ......  ....)
Ummon
  • Trade Count: (+13)
Re: Easiest fe?
« Reply #19 on: October 23, 2009, 02:47:29 pm »
Please don't say Mame32 or UI...
Rather you might've said, 'not including MAME32 or UI', mmm?
Ya bein screwed with, eh?  Admittedly, though I am fairly knowledgeable in this stuff, I wondered about it myself.
Yo. Chocolate.
Stephen Hawking
jeremymil
Re: Easiest fe?
« Reply #20 on: October 23, 2009, 03:33:59 pm »
Does it rally matter that much to ya?
« Last Edit: October 23, 2009, 03:39:09 pm by jeremymil »
speedklz
Re: Easiest fe?
« Reply #21 on: October 24, 2009, 04:37:42 pm »
I spent 20 min on google searching this elusive `maximo G+` to no avail. I am thinking to myself that this is some plot to help Google search numbers go up! So if there is a link I would like to see it. It is not listed on the wikki or on Zophars either. So it either dont exist or it has another more proper name.  :soapbox:
Cakemeister
Re: Easiest fe?
« Reply #22 on: October 25, 2009, 01:43:50 pm »
Actually, I just created a wiki entry for Maximo G+ on October 22.
http://wiki.arcadecontrols.com/wiki/Maximo_GPlus
For some reason, you can't have a "+" in an article title.
Gatsu
Re: Easiest fe?
« Reply #23 on: October 25, 2009, 03:25:28 pm »
I really like MaLa. It was easy to setup...and let me customize my own graphics and audio for the interface...which is a huge plus for me.
speedklz
Re: Easiest fe?
« Reply #24 on: October 26, 2009, 09:56:33 am »
 :badmood:
200X
  • Last login:May 25, 2010, 05:38:39 am
Re: Easiest fe?
« Reply #25 on: October 26, 2009, 12:08:48 pm »
Maximus Arcade, Hyperspin and Maximo G+ are the ones I use. I can't decide between them.
Ummon
Re: Easiest fe?
« Reply #26 on: October 26, 2009, 02:20:33 pm »
A neutral presentation often equals a clear and open mind.
Yo. Chocolate.
Stephen Hawking
FrizzleFried
    • Idaho Garagecade
Re: Easiest fe?
« Reply #27 on: October 27, 2009, 04:11:05 am »
Maximo G+ ... the front-end gift that keeps on giving.
 :laugh2:
