Author Topic: Arcade monitor SYNC question..  (Read 2614 times)
JoeB
  • Last login:February 12, 2026, 11:59:45 am
  • NES Fanatic
« on: July 17, 2003, 12:13:56 am »
I'm currently in the wiring stage of my MAME arcade, and I noticed something strange in the way my WG 25K7191 is wired up (from its previous life as an Xmen: Children of the atom arcade machine)
For this monitor, the hookups are as follows:
Pinouts of P1 are
Red
Green
Blue
Gnd
+Vert Sync
+Horiz Sync
Pinouts of P2 are
Gnd
-Vert Sync
-Horiz Sync
Well, I got wires going to P1 (R, G, B and GND) and I got a single wire going to P2.  This wire wraps around both the -vert and -horiz sync (i.e. combining the 2) and it goes back to the JAMMA harness and plugs into SYNC.
Is this normal?? Is this OK the way it is once I plug it into my I-PAC (and ArcadeVGA in turn) ??
Thanks in advance.
OSCAR
    • Oscar Controls
Re:Arcade monitor SYNC question..
« Reply #1 on: July 17, 2003, 12:42:25 am »
Combining the -Hsync & -Vsync is a standard JAMMA setup and is compatible with the ArcadeVGA.
For more info, see http://www.ultimarc.com/avgainst.html and http://www.ultimarc.com/monfaq.html#monitorcable.
FWIW, I have my W-G connected to an ArcadeVGA with just the -Hsync connection to the monitor (because that's how the monitor harness already was) and it works fine.
