Author Topic: U360 problems  (Read 1224 times)
theob42
  • Last login:December 23, 2012, 12:15:25 pm
U360 problems
« on: October 12, 2009, 01:38:55 pm »
hey guys, so i plugged in my 2 U360's and the orientation is off. up is down left is right etc. now i know i can probably fix this by screwing it back in upside down but is there a waay to reset it. ive tried using utlramap and I can make a custom map to fix the issue but then its gonna be a pain making other custom maps where every direction is all over the place.
secondly, on the second u360 stick i have plugged in, right is now up. so id have to route the hole sideways from the bottom (since the plate is rectangle), otherwise id have to use a custom map to get it to work properly. any ideas?
severdhed
  • RIP Dinosaur Hippo
Re: U360 problems
« Reply #1 on: October 12, 2009, 02:28:26 pm »
just unscrew the PCB and rotate it :)
theob42
Re: U360 problems
« Reply #2 on: October 12, 2009, 04:26:59 pm »
oh sweet. wasnt sure if that was possible
