Author Topic: Mame ok screen - joystick not working on this screen.  (Read 5487 times)
rooroosta
  • Last login:December 06, 2009, 08:04:00 am
« on: October 09, 2009, 04:51:16 pm »
I can't seem to use my joystick (left and right) to leave the OK screen on Mame (mamep variety)..this is a problem for me as i am using a cabinet for Mame..i am probably missing something simple but can't quite work out what it is..((i've already reconfigured the keyboard settings via mamep)
I would appreciate any help.. :)
BobA
  • What Me Worry?
Re: Mame ok screen - joystick not working on this screen.
« Reply #1 on: October 09, 2009, 06:36:12 pm »
Could you say what encoder you are using and have you checked the joystick operation in windows?
Hoopz
  • Intellivision Rocks!
« Reply #2 on: October 09, 2009, 07:22:54 pm »
If you reconfigured the keyboard settings, it may be that P1 left and P1 right aren't mapped to "O" and "K".
Ginsu Victim
  • Comanche, OK -- USA
« Reply #3 on: October 09, 2009, 09:43:23 pm »
They aren't usually mapped to that anyway.
Necroticart
  • Last login:October 19, 2025, 12:07:42 am
  • Welcome to my nightmare
« Reply #4 on: October 09, 2009, 11:44:25 pm »
i've noticed the problem to It happens to me when i'm using the madcatz sf4 te ps3 stick on my main PC I've not tried to find a solution to the problem since i'm not using the stick on my mame cab
rooroosta
« Reply #5 on: October 10, 2009, 02:50:34 am »
Yep, everything is working in windows and the actual Mame games..it's just getting past the OK screen using the joystick that's the problem...i'm using a generic USB encoder..been googling and can't find an answer yet...i'm sure it must be a simple solution.
Kevin Mullins
    • Me on Myspace
« Reply #6 on: October 10, 2009, 09:57:50 am »
So while in Windows.... if you open something like Notepad and move the joystick left and right..... what does it type ?
And then be certain that MAME has those keys also mapped the same to the letters "O" and "K".
rooroosta
« Reply #7 on: October 10, 2009, 05:17:51 pm »
I reinstalled Mame and made a new .ini file and it's all working as it should now..weird...thanks all.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #8 on: October 11, 2009, 05:50:32 am »
FWIW, mame is looking for 'O' or (whatever that's mapped to mame's) UI_left, then 'K' or UI_right.  Joystick 1 is mapped by default to player 1 left and right and UI_left and UI_right.  If you want to be able to wiggle any joystick on your 4 player CP, map all of them to mame UI_left and UI_right.
Sound like OP's default.cfg file (specifically UI_left or UI_right or both) got messed up.
Robin
Knowledge is Power
