Author Topic: USB Gamepad problem  (Read 4311 times)
Avinitlarge
  • Last login:February 01, 2020, 04:39:08 pm
    • iPhone For Free
USB Gamepad problem
« on: October 08, 2009, 02:37:29 pm »
I have 14 USB ports
4 X Onboard
5 X on a PCI Hub
1 X On the front of my card reader
4 X On a hub on my desk
When I connect a game pad to the onboard or Front USB I get this error USB Device Not Recognised It works fine in the other USB's. Ive tried 5 different gamepads and it still does the same. Any ideas??
bkenobi
Re: USB Gamepad problem
« Reply #1 on: October 08, 2009, 03:03:40 pm »
Don't use that port?   :dunno
Avinitlarge
    • iPhone For Free
« Reply #2 on: October 08, 2009, 04:27:45 pm »
All the other ports are in use.
Avinitlarge
    • iPhone For Free
« Reply #3 on: October 08, 2009, 07:32:58 pm »
Ive just checked what was plugged into the 4 onboard USB's, 4 extensions with nothing on the other end. Ive just fitted another 5 port PCI USB hub and Im not gonna bother with the onboard sockets. I tried quite a few things in them and nothng seemed to work.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #4 on: October 08, 2009, 07:43:23 pm »
Power, or lack there of.  Very common USB problem.
As you found out, use powered hubs to get around the issue.
Robin
Knowledge is Power
Beretta
« Reply #5 on: October 09, 2009, 12:34:30 am »
could be a power problem like was suggested.. heck i've had problems before just by adding an extension.. apparently 6 feet of cable was just enough power loss to make some things not work.. and i've had some boards that wont work with some usb devices.
so ya power could be the problem.
Avinitlarge
    • iPhone For Free
« Reply #6 on: October 09, 2009, 07:05:58 am »
It could be power, I just dont know. I did google it and it seems to be a very common problem which no one seems to beable to sort out. Im not bothered now, Ive now got 5 extra ports for connecting various gamepads, Card readers etc.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #7 on: October 09, 2009, 01:52:56 pm »
... heck i've had problems before just by adding an extension.. apparently 6 feet of cable was just enough power loss to make some things not work....
FWIW, about 99% of all USB extension cords are out of spec.  USB 2.0 specs forbids plain extension cords.  However, USB 2.0 allows for "one port unpowered hubs", which an on spec extension cord needs to be.  The reason USB 2.0 doesn't like raw extensions is the power & signal degradation, apparently mostly caused by the extra contact point (between the extension and the original cord), and secondly the extra length.
And yes, I use out of spec extension cords fairly regularly.  And usually they work fine.  But when a USB problem comes up, it's one of the first times I check.
Robin
Knowledge is Power
Beretta
« Reply #8 on: October 10, 2009, 04:00:38 am »
ah i was'nt aware of that USB 2.0 forbidden it.
actually the problems i've had was with 1.1 devices..
namely psx-usb converters & hacked xbox (original) controllers.. especially for example with rumble cranked up..
i've had some boards that could'nt support them with or without the extension.. i had this old 64mb thumb drive (usb1.1) that would'nt work on this one particular board with the extension cable.
i reckon those just end up being power issues and or weak boards.. 500ma goes pretty quick, in some cases i dont even think they was putting out that much to start.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #9 on: October 11, 2009, 05:37:04 am »
Not that is matters, but 1.0 okayed extensions, 1.1 depreciated them (recommended against them), and 2.0 said they can't be used.
Yeah, probably is a power problem, but not exactly the why you're thinking.  USB devices can request up to 500mA, but most only request 100mA (most thumb drives, mice, keyboards).  100mA goes even quicker than 500mA.  Which is why "one port hub extensions" are okay. The hub makes its own request, and can request 200-500mA, and then the device make its 100mA request, and the one port hub can supply the full request even with the extra cable.  And the unpowered hub wouldn't allow the full 500mA request, since the hub+extra cable is "using" 100mA; all unpowered hubs are spec'ed* to use 100mA and only allow up to 400mA total of all devices pluggin into it.
(*again, like extension cords, this spec isn't always followed)
Robin
Knowledge is Power
severdhed
  • RIP Dinosaur Hippo
« Reply #10 on: October 12, 2009, 03:28:42 pm »
just out of curiosity, what could you possibly have connected to your PC that you would be using 14 usb ports?
« Reply #11 on: October 12, 2009, 03:38:47 pm »
14 LEDwiz's and 154 RGB LED's...   8)
  • Last login:March 12, 2026, 08:50:34 am
    • GroovyGameGear.com
« Reply #12 on: October 12, 2009, 04:06:26 pm »
Heh, as wild as that sounds, we supplied 16 of them with unique ID's to a firm in NYC.  They used them to control lighting in a large architectural model, all of  them connected to one PC.
I was impressed too :)
« Last Edit: October 14, 2009, 12:09:27 am by RandyT »
ammitz
  • Last login:April 25, 2017, 07:22:09 am
« Reply #13 on: October 12, 2009, 04:14:28 pm »
How much power does that drain from the PSU?
Building my first bartop CAB
Beretta
« Reply #14 on: October 12, 2009, 05:32:32 pm »
well assuming 20ma per color per led, 60ma per led (peek all 3 colors at full)
9.24 amps
at 5 volt that would be = 46.2watts
at 12 volt = 110.88 watts
might be slightly off but thats ball park.
Avinitlarge
    • iPhone For Free
« Reply #15 on: October 21, 2009, 09:14:52 am »
Hmmm, Good point. Ive only got a printer, Keyboard/Mouse and the hub on my desktop connected. I guess I may have gone a little ott with the USB's
