Author Topic: Share your xlobby skin.. please  (Read 3761 times)
abispac
  • Last login:February 09, 2026, 12:30:42 am
« on: October 05, 2009, 03:02:55 pm »
I started using xlobby thanks to orion, now i would like to try more skins, planing on building a touchscreen juke, so why dont you share your xlobby skin so anyone ealse can try it, thanks
mountain
    • Mountain Jukeboxes
Re: Share your xlobby skin.. please
« Reply #1 on: October 06, 2009, 08:45:38 am »
Other than orion, I don't think there's a lot of people making skins for Xlobby around here. Using Google, I was able to find a lot of them when I originally found Xlobby last year.
Hewskie
  • Last login:July 27, 2018, 02:45:42 am
« Reply #2 on: October 06, 2009, 03:22:45 pm »
In my opinion, it's a good idea to do a bit of research and learn how to modify xlobby to suit your needs. In my case, I used the Colby skin 2 as a base and modified it like crazy, only to find that orion had done a kick ass way better job than me! So then I scrapped mine, and used his as a base. I still ended up modifying it slightly, but it turned out great.
Good luck,
Hewskie
abispac
« Reply #3 on: October 06, 2009, 04:28:31 pm »
Ill look in google for some skins, in the mean time, did you found any skns that where kind of diferent or cool?
orion
« Reply #4 on: October 06, 2009, 05:56:49 pm »
These two links will take you to pretty much every Xlobby skin posted. Keep in mind that some of them are for Pay lobby and won't work on free lobby and some need a lot of plugins ect loaded to get them running. You will need to check out the info for each skin before you try them out.
http://www.xlobby.com/forum/viewforum.php?f=12&sid=84b31c77ad642878112a8ece22811772
http://www.xlobby.com/downloads/skins
Hewskie is right, in that it's a good idea to make Xlobby suit your needs. That's what the designers had in mind in the first place, and to that end it is extremely customizable and can be used to create control software for a ton of different applications. The main fault I have with pretty much all of the Xlobby skins I tried is that the jukebox side to them are all pretty much the same (there are a few exceptions of course) and in my opinion no one really got the jukebox working intuitively nor were most of them laid out pretty well. This is why I put all the effort I did into learning how to skin Xlobby and in making up my skin.  Having said all that these are two of my favorites. I find them to be a bit of a pain to use, but they are still pretty cool!
http://www.xlobby.com/downloads/skins#27577
http://www.xlobby.com/forum/viewtopic.php?f=12&t=4072
mountain
« Reply #5 on: October 06, 2009, 07:49:52 pm »
I agree, that vintage skin looks really cool.
I like yours better though  :P
orion
« Reply #6 on: October 06, 2009, 08:11:47 pm »
Thanks mountain  :) Your project is what got me to try out Xlobby in the first place.
