Author Topic: Need advice on Rowe R87 trouble  (Read 3160 times)
John Zzz
  • Last login:June 25, 2011, 06:54:40 pm
« on: October 05, 2009, 12:42:36 am »
Upon power up, my Rowe R87 enters "continuous play" mode regardless of the play switch setting. After pressing "clear selection memory", all is normal. Any clues as to what might cause the juke to power up to "continuous play" mode? All opinions will be appreciated.
Thank You!
John Zzz
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Need advice on Rowe R87 trouble
« Reply #1 on: October 05, 2009, 06:06:59 am »
Hi,
You have a fault more than likely on your CCC.
You need to send your boards for testing, I would send the following so they can be tested and inspected for dry joints (called cold joints in the USA):-
CCC
Mechanism Control
Pricing Board
They need to go to a Rowe Ami speciaist for repair.
Regards
Alan Hood
ami-man
UK
alan-hood@datex.co.uk
John Zzz
« Reply #2 on: October 05, 2009, 11:45:05 am »
Thank you Alan, I'll have a look and report back.
John Zzz
« Reply #3 on: October 29, 2009, 12:50:43 pm »
Alan,
You were correct, the CCC had multiple troubles. The board was professionally repaired by Bruce Wentworth at A&B Jukebox Repair.
Thank you for your help.
John Zzz
ami-man
« Reply #4 on: October 30, 2009, 08:16:47 am »
Hi John,
Glad to hear that you have sorted out your problems on the CCC.
On your side of the pond Bruce is the man! and his work is legendary.
Regards
Alan Hood
ami-man
UK
