Author Topic: FS: Mitsubishi 19" Digital Multisync monitor Lexington, KY $100 (reduced!)  (Read 2558 times)
Jack Burton
I'm selling my Mitsubishi Diamondscan 20m monitor.  It is a PC monitor but it has the specs of an arcade monitor.  It is compatible with 15, 24, and 31khz resolutions.   You could use this for MAME or connect a PCB to it.  It is in excellent condition, has extremely good focus, contrast, and brightness, and absolutely no burn in.
I have looked at the inside of this monitor and underneath the plastic casing there is a metal housing around the chassis of the monitor.  I believe it would be very easy to decase this monitor and use it as a drop in replacement for any 19" arcade monitor.  You might have to drill some new holes on your mounting bracket, because this is actually a 20" tube.
Asking $150.
It looks like this:
Crap picture of mine running in the cab:
CRT
Size:  20"/ 19" Viewable
Gun: In line XF Gun
Deflection angle: 90 degrees
Dot trio pitch: 0.31 mm
face plate: Silica Coated non-glare
Input Signal
composite video: 1.0Vp-p RGB analog
composite sync: 1.5 - 5 Vp-p TTL Negative
Video: 0.7p-p analog RGB negative
separate sync: 1.5 - 5Vp-p TTL positive/negative
Interface
Input Connector: 15 pin shrinked D-sub/BNC Receptacle 5 pcs
Input Impedance: 75 ohms
Scanning Frequency
Horizontal: 15.7-38khz
Vertical: 45-90hz higher refresh rates result in the screen shrinking in from the sides.  At 90hz it's impossible to fill the entire screen.
Resolution
1280x768 (I've never been able to get it to go past 800x600)
Warm up time
30 minutes
Brightness:
90cd/m squared with STD CRT; standard white window video signal
Video Amplifier
50Hz-50Mhz plus or minus 3db
Blanking Time
Horizontal: 5.1 usec
Vertical: 600 usec
Linearity
Better than 7% (mine seems even better than this, it's almost perfect)
Raster Distortion
less than 2.5%
Raster size regulation
less than 1%
Misconvergence
Center: .35mm
Elsewhere: .5 mm
Display Size
350x265mm
Power Source
100-120VAC/220-240VAC plus or minus 10% 50/60hz 140w max
Operating Environment
Temperature: 0-40 degrees Celsius
Humidity: 10-95% RH without condensation
Cabinet Dimension
(W)495 x 9H) 496 x (D) 543mm (19.5 x 19.5 x 21.4")
Weight
32kg (70.6 lbs) A seriously heavy monitor.
Tilt Swivel Stand
Tilt Angle -5 - +10 degrees
Swivel angle: plus or minus 45 degrees
« Last Edit: October 07, 2009, 10:22:00 am by Jack Burton »
Franco B
Re: FS: Mitsubishi 19" Digital Multisync monitor Lexington, KY $150
« Reply #1 on: October 01, 2009, 07:53:40 pm »
Do you have a price in mind or are you taking offers?
(I'm not interested personally, I just couldn't see a price)
EDIT: Doh, just saw the price in your thread title after scanning your main post five times
« Last Edit: October 01, 2009, 07:56:16 pm by Franco B »
unclet
« Reply #2 on: October 02, 2009, 07:09:34 am »
Aren't people using monitors like these for doorstops now-n-days?
mytymaus007
« Reply #3 on: October 02, 2009, 08:19:30 am »
Im interested but its seems a bit pricey plus ill have to pay shipping to NY
Ginsu Victim
  • Comanche, OK -- USA
« Reply #4 on: October 02, 2009, 08:34:08 am »
If not for the cost of shipping, I'd buy this.
Jack Burton
« Reply #5 on: October 02, 2009, 10:17:23 pm »
Most of the ones people are using as doorstops are either very old or have significant power issues.
This monitor nearly brand new.  I purchased it from a computer dealer at the University of Kentucky auction.  It was still new in the box at the time.
I used it in my cab as a MAME monitor for about six months over the last year.
I guarantee this monitor not to be DOA, and to have extremely good performance.
I think considering the price of a new arcade monitor and the capabilities of this one it's a fair price.
mytymaus007
« Reply #6 on: October 02, 2009, 10:24:44 pm »
how much would it cost to ship to NY 11702
Jack Burton
« Reply #7 on: October 02, 2009, 11:44:42 pm »
I'm unsure what the best carrier to use for this sort of service would be.
The UPS shipping calculator will allow me to input an 80 lb. package and gives an estimated cost of $50.00 from 40504 for UPS ground.
I also have to include in the price of shipping any packaging materials I needed.  This would probably be a big cardboard box and plenty of packaging peanuts.  I suspect that will add an addtional $20 to the price.
For those who have shipped monitors, any tips?
« Last Edit: October 02, 2009, 11:47:37 pm by Jack Burton »
MonMotha
« Reply #8 on: October 02, 2009, 11:58:13 pm »
Use FedEx, not UPS.  Far less likely to end up with a hole in the monitor.  I don't normally advocate FedEx ground due to the difficulty dealing with them, but they have less of a tendency to mangle packages.
If you really want to be sure it gets there in one piece, build a wooden crate.  A double cardboard box (box within a box) is a suitable other option.
Don't use packing peanuts.  Use foam "sheets".  Preferably the stuff that compresses and spings back, not the stuff that dents.  Ship the monitor face down and clearly mark the box to be moved in only the orientation that keeps this the case.  Pad everything so that the monitor doesn't move.  Provide at least 2" of foam around all areas between the monitor and the box sides.
I know someone who MIGHT be interested in this.  I'll ask tomorrow.  Pick-up might be possible.
Ummon
  • Trade Count: (+13)
« Reply #9 on: October 04, 2009, 02:55:29 am »
Damn, I'd like to just see how this thing performs in person....
Yo. Chocolate.
Stephen Hawking
Jack Burton
« Reply #10 on: October 07, 2009, 10:21:38 am »
Price reduced to $100.
