Author Topic: Need help with my wireless router  (Read 1239 times)
Red
  • Last login:November 07, 2017, 08:37:51 am
« on: September 30, 2009, 12:32:41 pm »
Guys,
Any help on fixing this situation would be greatly appreciated.
I managed to set up my D-Link wireless router for my PC's at my Townhome using WEP Encryption and can connect with my notebook PC wirelessly when I type in the Key.
However, the problem is that every two minutes Windows XP will pop up a message saying that they found additional networks (Even when mine is the only one listed) and disconnects the signal until I click on my network and then click connect.
As I said, this happens every two minutes and is getting annoying to have to stop surfing and reconnect.  I've looked in the settings and options for a fix, but found nothing that solved this problem.
Is there a way to tell Windows to not look for additional networks to stop that message from popping up every two minutes and disconnecting me?
Thanks.
Red
Red
Re: Need help with my wireless router
« Reply #1 on: October 01, 2009, 01:26:37 pm »
Anyone?  I'm at my wits end on this.  Funny thing is, when I log onto my neighbor's unencrypted signal I can surf all day and never lose the signal because Windows XP never displays the "New Network Connection Found" box.  It only does that when I'm connected to my wireless router, strange.
I looked at all the settings on the wireless router, but nothing stood out that I should change to stop it.  Maybe I should just buy a new router?
Kevin Mullins
    • Me on Myspace
« Reply #2 on: October 01, 2009, 02:08:43 pm »
Is there a setting to have your notebook automatically connect to your network when available?
Hoopz
  • Intellivision Rocks!
« Reply #3 on: October 01, 2009, 02:49:08 pm »
See if there's additional software available for your wireless card.  My software has a setting to ignore other networks besides the one you want to connect to, and that may clear your issue.
Look at the settings on your PC instead of the router.  Go to Start - Control Panel - Wireless and see what's their.  It may be specific to your wireless card, it's software, etc like PBJ said.  It's probably not on the router side.
Red
« Reply #4 on: October 01, 2009, 08:21:41 pm »
Thanks for all the helpful suggestions, much appreciated.
I've checked and rechecked everything on my wireless setup in Windows XP and on the wireless card inside the notebook and nothing I do stops the "New Network Connection Found" box from always popping up every two minutes WHEN I'M ON MY NETWORK.
It never pops up when I'm on my neighbor's unsecured network, so that leads me to believe that it's either my router and security settings causing it or somehow my connection might be dropping out every two minutes, but I doubt it because when I use my main desktop hooked up to the router via Ethernet cable, the signal on my DSL modem doesn't drop out.
So, for now I'll just have to live with it or use my neighbor's signal lol.  BTW, can my neighbor "see" me using his signal?
Anyway, thanks again for all the help.
Red
smalltownguy
  • Last login:October 07, 2025, 12:45:27 pm
« Reply #5 on: October 01, 2009, 08:33:25 pm »
Few possible causes:
1. Signal attenuation. Do you have any other wireless devices broadcasting in the area? Any powered antennas?
2. Security issue. If you're using XP to manage your wireless settings, you may need to remove the stored profile for that wireless network, and start from scratch. I've noticed that on my wireless network I get that same behavior when I've connected to the router but not authenticated. The signal repeatedly connects and disconnects, never allowing packet transfer.
3. The wireless transmitter in your router is failing. This happened to one of my Belkin units recently, and it needed to be replaced. It would 'sieze up' from time to time, requiring a reboot.
I use a wireless laptop at work and travel between multiple locations, each with different wireless settings, using static IP addressing. If you need further help, PM me and I'll see what I can do for you.
« Last Edit: October 01, 2009, 08:36:02 pm by smalltownguy »
