Author Topic: no image  (Read 5015 times)
michiel
  • Last login:December 10, 2009, 02:56:41 am
no image
« on: September 25, 2009, 03:55:00 pm »
Hi all,
I have a original Arcade system with a Jamma 48 in 1 game board.
As the monitor broke I have used it in combination with a VGA monitor connected
to the connector on the circuit board. It has worked in this set-up for a while, but now doesn't anymore however.
Now when the monitor is connected to the board, the system doesn't start at all.
 With the monitor cable removed, it does start, without any visuals off course (I know this because of the game sounds). The main menu and the games all work, however when I connect the monitor, the system dies while lighting a red led on the circuit board. When I disconnect the monitor cable the system boots automatically again.
Is there anyone who has a clue what is causing this?
Thanks in advance!
Michiel
Kevin Mullins
    • Me on Myspace
Re: no image
« Reply #1 on: September 25, 2009, 04:18:38 pm »
Have you tried a different monitor ?
michiel
Re: no image
« Reply #2 on: September 25, 2009, 04:28:39 pm »
Yes, with no result.
Kevin Mullins
    • Me on Myspace
Re: no image
« Reply #3 on: September 25, 2009, 05:34:29 pm »
Were any settings or dipswitches changed when this happened ?
There is a dipswitch to switch between RGB and VGA.
Switch #2 should be ON for VGA mode.
michiel
Re: no image
« Reply #4 on: September 26, 2009, 05:59:34 am »
nothing was changed.
And switch 2 is ON
michiel
Re: no image
« Reply #5 on: October 10, 2009, 05:35:36 pm »
Swith #1,3 and 4 are off.
Is that ok?
Kevin Mullins
    • Me on Myspace
Re: no image
« Reply #6 on: October 10, 2009, 06:11:42 pm »
Yes, those are OK.
#1 Flips the screen
#2 CGA or VGA selection
#3 High Score Saver on or off
#4 Doesn't use
michiel
Re: no image
« Reply #7 on: November 07, 2009, 03:44:01 pm »
Is there someone who have an other idea to solve the above problem...?
grantspain
Re: no image
« Reply #8 on: November 07, 2009, 04:24:47 pm »
maybe something as stupid as low +5 volts or even an issue with earth
michiel
Re: no image
« Reply #9 on: November 07, 2009, 04:34:43 pm »
Thanks for your reaction.
How can i check this.
grantspain
Re: no image
« Reply #10 on: November 07, 2009, 04:44:36 pm »
you would need a multimeter to check both
michiel
Re: no image
« Reply #11 on: November 07, 2009, 05:19:43 pm »
I have a multimeter.
What will i measure...?
grantspain
Re: no image
« Reply #12 on: November 07, 2009, 05:38:24 pm »
check on the jamma connector from pin 1(ground) to pin 3(+5),you should have a minimum of 5.05 and a max of 5.15
if that checks fine then read continuity from the earth point of the cab to the monitor frame,if checking ohms it should be less than 1 ohm(ideally around 0.3)
michiel
Re: no image
« Reply #13 on: November 07, 2009, 05:45:57 pm »
I will check it.
michiel
Re: no image
« Reply #14 on: November 10, 2009, 03:10:13 pm »
The results of measuring are:
From pin 1 to pin 3 =  5.3V
From pin 1 to pin 5 =  5.6V
From earth point to monitor frame = 0.5 ohm
The voltage is to high? :-\ What does this mean?
Gr.
Michiel
grantspain
Re: no image
« Reply #15 on: November 10, 2009, 04:53:09 pm »
you have +5.6v from 1 to 5 or -5.6v?
you +5 is a little high
michiel
Re: no image
« Reply #16 on: November 12, 2009, 02:52:38 pm »
from 1 to 5 is +5.6V
Is that a problem...?
grantspain
Re: no image
« Reply #17 on: November 12, 2009, 05:01:03 pm »
pin 5 should be -5v not +5-disconnect that wire and try
michiel
Re: no image
« Reply #18 on: November 15, 2009, 03:47:30 pm »
If i put the red stick from the multimeter on pin 1 and de black stik on pin 5 it is +5,6V
And black on pin 1 and red on pin 5 is -5.6V
Should red be on pin 1 or pin 5?
The wires  are still connected.
grantspain
Re: no image
« Reply #19 on: November 16, 2009, 01:50:15 pm »
always the black probe(ground) to ground(on jamma pin 1)
michiel
Re: no image
« Reply #20 on: November 16, 2009, 02:15:40 pm »
Ok, with the black probe on pin 1 and de red on pin 5 i measure -5,64V
so that is ok besides it's a little high...?
grantspain
Re: no image
« Reply #21 on: November 17, 2009, 04:29:26 pm »
have you checked a pc lcd monitor on the game board yet?
michiel
Re: no image
« Reply #22 on: November 19, 2009, 04:08:23 pm »
Yes i have tryed my lcd monitor but with the same result... :(
grantspain
Re: no image
« Reply #23 on: November 19, 2009, 04:14:54 pm »
disconnect the -5,check the +12volts
michiel
Re: no image
« Reply #24 on: November 20, 2009, 04:44:13 pm »
how can i check the 12V?
grantspain
Re: no image
« Reply #25 on: November 20, 2009, 06:00:42 pm »
pin 1 = ground
pin 6 = +12v
michiel
Re: no image
« Reply #26 on: November 23, 2009, 04:16:17 pm »
pin 6 = 12.32V
Pin 5 is disconnected
