Author Topic: How to make SPST switch to switch DPDT  (Read 3175 times)
david656
  • Last login:June 01, 2017, 10:06:24 am
  • Big Man!
« on: September 24, 2009, 03:30:42 pm »
I'm sure its simple and involves some kind of relay or something but its just not coming to mind.
Does anyone know how i can make a simple locking SPST switch flick a DPDT type switch
Ed_McCarron
Re: How to make SPST switch to switch DPDT
« Reply #1 on: September 24, 2009, 06:05:34 pm »
Use the spst switch to energize a dpdt relay.
Code: [Select]
--------------- voltage source---
spst                             |
---------------dpdt coil-----------
                  ---------------------- NO 1
COM 1---------
                \ ---------------------- NC 1
                  ---------------------- NO 2
COM 2---------
                \ ---------------------- NC 2
Clear as mud?
danny_galaga
  • Last login:February 16, 2026, 07:16:44 pm
    • dans cocktail lounge
« Reply #2 on: September 25, 2009, 07:08:14 am »
what he said. Most relays have the circuit diagram written on them too so you shouldn't go wrong. just be wary of the voltage you need to be switching and the voltage the relay needs to operate. In your case you will probably want the same...
Ed_McCarron
« Reply #3 on: September 25, 2009, 08:17:05 am »
Yup.  Match your coil voltage to whatever spare voltages you have floating around.  Use 12v or 5v from one of the drive connectors (yellow = 12v, red = 5v) and you'll be golden.
whammoed
  • Last login:February 17, 2026, 12:42:21 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #4 on: September 25, 2009, 12:12:39 pm »
What is keeping you from changing out the SPST switch to a DPDT?  Seems like that would be easier.
danny_galaga
« Reply #5 on: September 26, 2009, 06:42:10 am »
i assumed the term 'locking spst' meant it is something kinda special you cant get in a dpdt  :dunno
whammoed
    • NiceMite
« Reply #6 on: September 26, 2009, 09:52:14 am »
Yeah, not sure about that but here's one that says locking for 0.99:
http://www.sourcingmap.com/15a-high-electrical-current-dpdt-centre-off-screw-terminal-locking-toggle-switch-p-32172.html
SavannahLion
« Reply #7 on: September 26, 2009, 01:32:18 pm »
Note the $5 shipping.
NiN^_^NiN
« Reply #8 on: September 29, 2009, 12:30:08 am »
