Author Topic: K7000 50/50 hz pot  (Read 2342 times)
Cisek
  • Last login:May 19, 2023, 07:35:14 am
K7000 50/50 hz pot
« on: September 24, 2009, 10:40:36 am »
Hi
I have a question about this pot on the flyback: If I adjust it to 60 hz, than games like mortal kombat are cut off at the bottom (it runs 53 hz) and if I adjust this pot to 53 hz, than when in 60 hz resolution, there is a squeeze at the upper lines. Is there possibility to adjust it, that 50 and 60 hz resolutions will display properly? It would be great as I use a mame cabinet with soft15khz and I change games and resolutions a lot.
Ken Layton
  • Guru
  • Technician
Re: K7000 50/50 hz pot
« Reply #1 on: September 24, 2009, 11:12:51 am »
This monitor was designed for use with one game only in a commercial use. You set it once for the installed game. It was never meant nor designed to be changing all the time like in a MAME setup
Cisek
« Reply #2 on: September 24, 2009, 11:48:38 am »
That is exactly what I thought. It is strange feature though, because 8liners chassis didn't have any problem with that.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: September 24, 2009, 12:20:51 pm »
The k7000 was designed in 1985. The Jen Shinn and Wei-ya chassis sold by 8liners are modern designs from 2000.
Cisek
« Reply #4 on: September 24, 2009, 03:16:51 pm »
I didn't know they are this old, thanks for info. Anyway it is not a big problem.
I was wondering also if there are ways to obtain more vibrant colours on my K7000. I know it is very old, but in comparison to what can produce my 12 year old Samsung tv in scart rgb mode, it looks weak. I have made capkit and I use ultimarc video amplifier and everything looks ok, but I would like to "boost" it a little. Is it possible?
MKFan4Life
  • Last login:July 24, 2023, 08:18:00 am
  • My arcade machines...
« Reply #5 on: April 07, 2010, 11:38:07 pm »
Sorry to reply to an old post, but nobody answered him.  You can get the tube "rejuvenated" at a local tv repair shop.  (heard people say it is likely $25-$70)  This helps the emmisions of the guns in your tube from what I have read.  It can also find other faults when they use the device to check your tube out and can fix some of the problems like certain types of "shorts".
I wanted to get this done on a K7000 I just got in an MK1 cabinet, but figured I'd go the whole 9-yards and went ahead and bought a rejuvenator off of Ebay so I can learn to do it and have it around for future use.  I got a great deal on one for only $75 with shipping ($65 after a $10 Ebay bucks rebate I earned).  So now hopefully I can bring new life back to the old monitor.
Take notice though, some people say there are chances of damaging a tube beyond repair with this process.  More people seem to see vast improvements than catastrophic failure, though.
  • Last login:January 19, 2026, 06:58:37 pm
« Reply #6 on: April 08, 2010, 11:14:10 am »
just a thought,
you could wire up 2 pots (matched to the 50/60hz pot) and remove the original pot... wire up a toggle switch to switch between an adjusted 53 hz pot and another adjusted to 60hz
