Author Topic: Blue Screen of Death Options??  (Read 10330 times)
Flake
  • Last login:January 11, 2025, 01:16:20 pm
  • I am Evil Homer....I am Evil Homer....
« on: September 24, 2009, 10:09:02 am »
I got the blue screen of death on my mame PC last night.  The previous time I had used the pc the last thing I did was to run a disk clean-up and defrag because I thought the pc was running slowly through my front end (maximus arcade).  After the defrag I turned off the computer and last night was the first time I turned it back on and.......blue screen of death appears.
So I would like to explore my options of recovery.  I dont have a Windows XP boot CD.  The PC I purchased from E-bay and all it came with was a two disk set of what appears to be a version of Acronis True Image.  I dont have any experience with the software and for now am hesitant to go any farther for fear of wiping my HD clean.
My issue on the blue screen stated it was a "unmountable boot volume".  I found a fix online for this particular problem but they start with using the XP boot cd, which I dont have.
So if I go through the Acronis True Image prompts will I be OK?  Should I attempt to track down the windows boot CD rather than using the Acronis software?
severdhed
  • RIP Dinosaur Hippo
Re: Blue Screen of Death Options??
« Reply #1 on: September 24, 2009, 11:10:35 am »
the acronis software would be used to completely recover your PC back to the state it was in when you got it.  Often times when you get errors like that, it is due to physical problems with the hard drive.  Is it making any kind of whining or clicking sounds?  if you are worried about data loss, i would reccomend installing that hard drive in another computer as a second drive to backup your data.
you will need a windows xp CD if you want to try to fix this.
here is a link to a great article on how to recover from alot of windows xp startup problems, i have used this method many times and i have a pretty high success rate.  the only times it doesnt work is usually because of hard ware failure, or that the installation is so far gone that it needs reinstalled.
http://icrontic.com/articles/repair_windows_xp
Flake
« Reply #2 on: September 24, 2009, 11:24:01 am »
So is this XP boot CD the same as the install CD.....like say if I walked into a store and purchased a brand new copy of XP?
severdhed
« Reply #3 on: September 24, 2009, 11:51:01 am »
yes...the xp install CD is bootable.  it will allow you to boot up to the recovery console, or boot up into setup to do a repair install, or a clean install.
i'd just be a little concerned about the status of your hard drive based on that error
Flake
« Reply #4 on: September 24, 2009, 11:55:54 am »
What if the xp install cd is a different one from the one that was used to install my copy of xp?  Is there going to be any license issues?  Or can I just use it to access the recovery console and be done with it from there?
Well the error I posted seems to be one of more common blue screen error messages and there are tons of links out there saying its an easy fix.  Hopefully they are right.  I dont have much experience removing/adding computer components.
One more question, I keep reading about the XP boot disks as being comprised of 6 floppy disks....WTF is that all about?  What if you dont have a floppy drive as most computers dont anymore?  How do you use them on a CD/DVD ROM only computer?
severdhed
« Reply #5 on: September 24, 2009, 12:11:37 pm »
xp boot floppies are not needed for anything...only if you cannot boot from the CD rom.  If you have to reinstall, you will need a xp disc that matches the license number you plan to use.  if you have an oem xp home license number, you cannot use an xp pro retail CD...etc.
it can be a pain in the butt.
Flake
« Reply #6 on: September 24, 2009, 12:17:31 pm »
Well OK here is a "fix" I found for this problem but it states you need the XP Pro boot CD.
http://www.techtips4u.com/kb/sw/SW00014.htm
This fix seems to imply you only need the CD to get to a certain point to fix the problem but then dont need the XP Pro boot CD after that point.  So can I use a different XP Pro CD (other than the one used to install my copy of windows) to go through this trouble shooting solution and fix my problem?  This fix seems to imply I will not need to reinstall windows.
If I'm just going to reinstall windows I could just use my Acronis software.  And if that is the case I think I will try and move and copy my HD first.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #7 on: September 24, 2009, 12:21:58 pm »
BSOD can be anything, from faulty hardware to bad drivers, etc...
First thing I do is clean out dust and re-seat my (cleaned) RAM sticks. Check the video card is snug.
Then boot and see what happens.
NO MORE!!
bkenobi
« Reply #8 on: September 24, 2009, 01:11:33 pm »
After reseating components, another thing you can do is remove all non-critical hardware and boot again.  Take out any extra sticks of memory, secondary (or more) HDD's, sound cards, network cards, etc.  Basically, take the system down to bare bones.  If it boots that way, you can start adding things back in.
Also, try going into safe mode.  That will more or less eliminate drivers as the cause.  Hold down F8 when Windows just starts to boot.  I would go without network to start with since it's quicker and not needed for this check, but whatever.
Flake
« Reply #9 on: September 24, 2009, 01:13:26 pm »
It wont let me boot into safe mode.  Once I select safe mode, a list of drivers scrolls out and then the BSOD reappears.
All this after a damn defrag.  I thought that was supposed to be beneficial to a computer?
paulscade
  • Last login:December 26, 2022, 09:40:35 pm
    • My Arcade Project - Blastoff!
« Reply #10 on: September 24, 2009, 01:16:43 pm »
At boot... press F8.... select "boot from last known good configuration"... it's the *easiest* fix... if it works.
... Why is it that you always find it in the last place that you look? ...
Flake
« Reply #11 on: September 24, 2009, 01:17:33 pm »
Tried that too.....doesnt work.   :dunno
bkenobi
« Reply #12 on: September 24, 2009, 01:22:44 pm »
http://support.microsoft.com/kb/555302
Translation:  If you didn't change anything in your hardware or BIOS,  you are F'd.
It sounds to me like there's a problem with the partition.  The only thing I can suggest is to try recovering the files from the drive by installing the drive in another machine (like was mentioned earlier).  This is the kind of error you really need a XP cd for.
You could try buying a new disc and running the repair utility, but if the HDD is toast, that won't help.  If you can mount the disc on another machine and access the files, you can at least save that stuff before you have to reformat and start over.
Flake
« Reply #13 on: September 24, 2009, 01:27:36 pm »
I am going to get a copy of a XP CD from my brother and try to access the recovery console that way.  Hopefully you can access this with any XP CD.
bkenobi
« Reply #14 on: September 24, 2009, 01:45:31 pm »
You won't have a problem with licensing unless the version you have installed is something completely different (Home vs Pro vs Corporate (which is mass licensed Pro)).
dtechlogic
  • Last login:July 09, 2010, 04:46:57 pm
« Reply #15 on: September 24, 2009, 02:29:26 pm »
Hi
Just download a copy of Linux knoppix  to boot the pc and transfer your mame to another partition or create another partition and transfer the files to it and then reinstall the OS.
RayB
  • There's my post
    • RayB.com
« Reply #16 on: September 24, 2009, 03:39:23 pm »
I got this problem recently too! It was due to corrupted data in the master boot record.
I booted to command line (I think via my XP install disc...??? Maybe when selecting Repair option?)
So then in command line, I could not see the files of the C: drive anymore so I ran CHKDSK with the repair option.
It found bad sectors, and whatnot, fixed them, and then I was able to boot to Windows again.
NO MORE!!
Flake
« Reply #17 on: September 24, 2009, 03:45:19 pm »
You mean you got the same unmountable boot problem and were unable to start up in safe mode?  What exactly was your problem?
I'm really hoping the fix I found (posting in an earlier post) on the internets via the XP install CD works for me.
RayB
  • There's my post
    • RayB.com
« Reply #18 on: September 24, 2009, 03:50:57 pm »
Maybe not EXACTLY, but sounds similar.
What I got was a BSOD one day while working, and then Windows would no longer boot. It would start loading, showing the logo and then it would just reboot again, and did this over and over. Going into SAFE mode did the same thing, it listed drivers it was loading and then POOF it reboots.
C: drive wouldn't list files. Said there was some error.
Now I just noticed you said you defragged, but did you defrag with full error checking and repair? Just try running CheckDisk (CHKDSK command) with the full repair option and see what happens. (Can't hurt at this point)
NO MORE!!
severdhed
« Reply #19 on: September 24, 2009, 03:54:06 pm »
yeah, i'd boot from the xp cd, get to the recovery console, then run a chkdsk /r first. then if that doesnt work, i'd go through the process in that link i posted where you run bootcfg /rebuild.
Avinitlarge
  • Last login:February 01, 2020, 04:39:08 pm
    • iPhone For Free
« Reply #20 on: September 24, 2009, 04:34:35 pm »
I would buy a small HD, 10Gb or so. Install windows on it, Use the drive you have fitted at the moment as a secondary/Slave. See how it goes from there. If its just an OS problem, Your mame, Docs or what ever you have on there should be safe. If you have no windows disk, See if you could borrow one or get one from a source I am not allowed to mention ;)
Encryptor
  • Trade Count: (+34)
« Reply #21 on: September 24, 2009, 04:50:58 pm »
It probably wasn't the defrag that did the damage. It was probably the disk cleanup which I NEVER do. I've never had defrag cause a problem like this.
Try the chkdsk /r solution first.
Encryptor
Ummon
  • Trade Count: (+13)
« Reply #22 on: September 25, 2009, 12:35:42 am »
Man, I haven't seen 'the screen' in ages on my XP machines.
Yo. Chocolate.
Stephen Hawking
Encryptor
« Reply #23 on: September 25, 2009, 06:38:16 am »
Flake,
Check your email.
Encryptor
KissMyWookie
  • Last login:September 18, 2014, 04:57:34 pm
« Reply #24 on: September 25, 2009, 08:42:59 am »
What probably happened was the defrag moved data onto a sector that turned out to be bad ... though I assumed defrag tools verified the data after moving it?
If you have access to another PC, I would download and use "Hiren's Boot CD". It has lots of repair and recovery tools, along with a mini-XP that you can boot into to perform repair tasks on NTFS partitions.
Usually, you would burn it onto a CD (less than 120MB) and select the BIOS on the target machine to boot from the CD drive. You can also install it onto a flash drive (like I did the last time I used it), providing the BIOS allows you to boot from USB flash drives.
Once booting starts and you see a menu, select to boot XP-lite/mini-XP (or whatever it's called - can't remember exactly). Open Windows Explorer and find your drive letter, as they will all be different to what you're used to - the mini XP will take C: and there will also be a ramdrive setup to take another drive letter. When you know which drive letter your old system is on, open the command window (WINKEY+R -> "cmd.exe" -> ENTER) and type "chkdsk [driveletter]: /r" - where [driveletter] might be D, E or something.
The full surface scan will take a long time, but will try to locate the bad sectors and attempt to recover information. You may end up with something that still needs fixing - such as a driver file or windows executable that was corrupted and could not be repaired, but I'll keep my fingers crossed for you.
Steve
Flake
« Reply #25 on: September 25, 2009, 09:23:58 am »
Flake,
Check your email.
Encryptor
Thanks for the info  (actually thanks to all for your recommendations/comments).  I'm getting a copy of the XP install CD tonight at a wedding I have to go to.  I will try the recovery console solution tonight.........maybe........depending on how much I've had to drink.
Wish me luck
Flake
« Reply #26 on: September 26, 2009, 04:32:28 pm »
well using the XP install cd to access the recovery console and running a check disk command didnt work.  It only goes to about 35% and says there are one or more unknown unrecoverable errors and that the bootdisk is bad.  I did a fixboot command which says it performed successfully but it still wont work.
Have to try other options posted here, but I was really hoping that one worked.  Does this mean I have a hardware failure?
severdhed
« Reply #27 on: September 26, 2009, 04:52:10 pm »
that usually means that the drive is bad.  your best be here would be to install the drive in another computer to back up your data (if you need any of it) and get a new hard drive and start from scratch.
chrimeg
  • Last login:December 30, 2011, 07:12:31 pm
« Reply #28 on: September 26, 2009, 07:17:12 pm »
if you get or have an XP boot disk/CD get to the rvocery console/dos prompt and use the following.
chkdisk /r
This should check your hard drive for bad sectors and repair them. If you are able to boot windows after this use norton ghost or something to transfer your old hard drive onto a new one.
I'd bet your hard disk has bad sectors and defraging caused some sort of corruption when reorganizing the data.
Flake
« Reply #29 on: September 26, 2009, 10:17:51 pm »
chkdisk /r
I already did this with no success.  I have a Acronis recovery disk but someone stated this would restore my PC to its original point.  My whole aim here is to get my computer working without having to start from scratch.  I have all my hard drive backedup as much as I need to but I am trying to avoid all the other software downloads/driver/codec/cab vol/etc/etc/ installs/configs.  Plus if I remember right, I had a hellava time even getting my video card to output to my TV.  All this I'd like to avoid.
severdhed
« Reply #30 on: September 26, 2009, 10:24:15 pm »
well, i dont know if the acronis recovery disk is different than the standard acronis boot disk, but here is what i would do:
buy a new hard drive and install it as a second drive in the computer
boot from the acronis boot CD and choose "clone disk"
walk through the process to clone your old,defective disk to the new one, it will probably have a bunch of errors, tell it to ignore them.  this will take a long time (probably several hours)
once this is done, remove the bad drive, then boot from the windows xp CD, go to the recovery console, and do the chkdsk /r again.  this time it should not have any problem repairing the file structure.  once that is done, you can hopefully boot back up into windows, assuming that your system files werent too far gone.  you may be missing some things here and there, but more than likely the majority of your stuff should be intact
i have used this method dozens of times when people bring me PCs with problems similar to yours...it usually works
Flake
« Reply #31 on: September 27, 2009, 12:56:47 am »
Thanks dude, this seems like my best option so far.
Questions:
1.  Installing the second drive - all I have to do is install the hardware component?  What I mean is I dont have to have windows up and running for this to occur?  The reason I ask is I cant obviously boot into windows so I just want to clarify that all I have to do is  add hardware and the pc wll automatically detect it.
2.  The Acronis software - never used it before but I assume I can try using this software and if for whatever reason it doesnt give me a "clone" option I can abort at any time without already starting the process of wiping my hard drive clean?  I dont want to get into the process and then have no way of reverting back.
RayB
  • There's my post
    • RayB.com
« Reply #32 on: September 27, 2009, 01:38:50 pm »
UH, you definitely add a harddrive with the POWER OFF, so obviously no Windows running.
NO MORE!!
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
« Reply #33 on: September 27, 2009, 04:42:51 pm »
Let me know what the blue screen is.  I need the 0x000000, just the first one, and if it's inaccessible boot device, page fault in non paged area, etc.. please.
severdhed
« Reply #34 on: September 27, 2009, 05:51:03 pm »
yeah, shut the PC off and connect the second drive.  if you are using IDE drives, make sure the jumpers are set properly.  i dont know what is on the acronis disk you have, if you are worried, you could always disconnect your old hard drive and boot from the acronis disk to see what it does.
Flake
« Reply #35 on: September 27, 2009, 08:38:47 pm »
0x000000ed (00x8b091030, 0xc000009c, 0x00000000, 0x00000000)
thats all it says other than the text about "your computer has detected an error..............."
KissMyWookie
« Reply #36 on: September 28, 2009, 01:39:36 am »
What was the defrag and disk cleanup tools that you used - was it a Powerquest product by any chance? ...As I searched those error codes and just read something about a problem with a Powerquest driver (pqv2i.sys) causing similar errors: http://support.microsoft.com/kb/892000
Steve
Flake
« Reply #37 on: September 28, 2009, 09:04:55 am »
Just normal windows desk cleanup and defrag utility you access through applications from the start button.
Flake
« Reply #38 on: September 28, 2009, 02:50:02 pm »
One other tidbit I have forgotten to mention is that oddly enough, my USB keyboard didnt work after this error popped up.  I had to get an older keyboard with those older pin connectors.  Also, I'm not sure my IPAC is registering either since I couldnt use my mouse cursor using my control panel trackball after I had popped in my Acronis CD at one point.
Whats the deal there?
severdhed
« Reply #39 on: September 28, 2009, 02:56:59 pm »
i have had problems with acronis boot disks not recognizing ps2 mice if usb mouse support is enabled in the bios
