Author Topic: Capped my WG K4600, still have really bad foldover.  (Read 3024 times)
Mimatt
  • Last login:February 13, 2011, 11:59:28 pm
« on: September 23, 2009, 11:54:38 pm »
I've re-capped it. Checked all the soldering, adjusted every dial I can find, everything seems to be ship shape.
The color and picture look as sharp as it did in 1981 - the part you can see, anyway... But as you can see, the left side of the screen has really bad foldover. If I adjust the width any higher, the right side folds over too. I also can degauss my tube, there is still discoloration in the lower left side of the screen.
Is this a width coil problem, a HOT problem, or should I re-cap all the brown film caps? I can't find any flaws in the tube or neck.
« Last Edit: September 23, 2009, 11:57:34 pm by Mimatt »
Ken Layton
  • Guru
  • Technician
Re: Capped my WG K4600, still have really bad foldover.
« Reply #1 on: September 24, 2009, 12:05:59 am »
So you already recapped these boards on the monitor:
main board
XY (hor/ver) board
video interface board
power supply board
And you still have foldover? Then replace both vertical output transistors on the XY (hor/ver) board.
Mimatt
« Reply #2 on: September 30, 2009, 06:31:58 pm »
I don't have much electrical repair experience beyond capping a monitor.
Which two are the vertical output transistors? Are those TR306 and TR352?
« Last Edit: September 30, 2009, 10:20:43 pm by Mimatt »
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #3 on: October 03, 2009, 07:15:43 pm »
double check caps for correct polarity.
 then recheck:
c306 2.2uF/50v
c303 47uF/50v
c310 22uF/16v
qrz
