Author Topic: Happ coin mech screw size  (Read 1380 times)
khargy
  • Last login:October 03, 2017, 09:15:27 pm
« on: September 22, 2009, 02:54:51 pm »
I'm just about finished my first arcade (yay!)... one minor thing I have left is to switch out of standard yellow reject buttons to blue and red. I have a Happ 2-player coin door (#40-0008-00). As far as I can tell I need to remove the coin mech (or at least the top two screws) to remove the reject button housing... for the two screws on the center of the housing I used a 3/16th nut driver w/ no problem, but for the nut screws on the right the 3/16th is too big... and I can't for the life of me figure out what size it is... Anybody know what size those screws are?
Applekid
  • Last login:May 03, 2015, 10:16:28 am
Re: Happ coin mech screw size
« Reply #1 on: September 22, 2009, 07:26:41 pm »
I personally used a 3/16 long socket for all of them. It didn't fit quite perfectly but it was the smallest I could find that was still deep enough to reach that close by the reject cups.
Out of the 7 per coin chute x 4 chutes (28 screws), I had one screw (just one) that simply wouldn't budge. I brought out the Dremmel and cut a slot in the head but even with a screwdriver it was pretty tough. I was considering replacing them with standard screws but I don't think I'd be doing that again to that coin door anytime soon. Thank goodness.  ;)
MonMotha
« Reply #2 on: September 22, 2009, 08:22:54 pm »
Tried metric 4mm?  Most of Happ's stuff is made in Europe or Asia and is designed in metric.
khargy
« Reply #3 on: September 24, 2009, 10:23:54 pm »
Ok, I got it... they all are 3/16th it just so happened that the 2nd screw I tried was over tighten in such a way that it was actually recessed a bit... once I got the other ones off I was able to muscle that one off as well!
