Author Topic: Ledblinky U360 restrictor plate question  (Read 2841 times)
Keechwa
  • Last login:December 29, 2009, 06:54:14 pm
« on: September 19, 2009, 12:55:54 am »
First off, LedBlinky is an amazing program, thank you Arzoo for creating and maintaining it.
I know there's an option in LedBlinky that let's it know a U360 restrictor plate is installed, but is there anyway to tell it exactly which type of restrictor plate it is?
As it stands right now, I would like to use the Custom:5 setting for the plates, which works great when set with UltraMap. However, when I have LedBlinky automatically set the maps, with LedBlinky's internal "use restrictor plate" setting either on or off, the Custom:5 scaling is overridden with either the default no restrictor or the circular restrictor plate scaling by default. Is there any way to set the type of restrictor plate scaling I want it to use?
Thanks in advance!
arzoo
  • Last login:January 26, 2025, 08:51:53 am
  • Robots WILL kill you.
    • LEDBlinky
Re: Ledblinky U360 restrictor plate question
« Reply #1 on: September 19, 2009, 09:42:39 am »
Thanks in advance!
I'll have to look into this.
Robots will kill you.
Arcade Addiction
headkaze
  • 0x2b|~0x2b?
« Reply #2 on: September 19, 2009, 10:04:32 am »
My UltraStick.dll library can turn restrictor support on or off but currently it does not allow programming the different types of restrictors. I'll e-mail Andy and ask him how it's done so I can add support for it.
« Last Edit: September 19, 2009, 10:06:23 am by headkaze »
Keechwa
« Reply #3 on: September 19, 2009, 12:17:54 pm »
Oh okay, thanks a lot guys  :)
arzoo
    • LEDBlinky
« Reply #4 on: September 19, 2009, 10:06:20 pm »
Just to clarify - LEDBlinky uses headkaze's u360 library. So if he's on the case it'll get done ;D
Arcade Addiction
Keechwa
« Reply #5 on: October 02, 2009, 09:04:04 pm »
Hey Headkaze, any luck on fixing the problem?
headkaze
  • 0x2b|~0x2b?
« Reply #6 on: October 02, 2009, 09:15:42 pm »
Andy sent me the info and I will be doing an update very soon (I just need to clarify something with Andy).
Keechwa
« Reply #7 on: October 02, 2009, 10:20:49 pm »
Oh okay, great! Thank you very much.
