Author Topic: I-PAC USB???  (Read 1372 times)
Gromet
  • Last login:October 31, 2003, 10:11:45 am
I-PAC USB???
« on: July 14, 2003, 12:49:33 pm »
Ok, what functionality do you get out of using the I-PAC in USB instead of just regular PS/2 mode?   What is the prefered method?
Thanks.
Lilwolf
Re:I-PAC USB???
« Reply #1 on: July 14, 2003, 12:53:39 pm »
None... But what usb gives you (plug-n play mainly).  Both work GREAT!
Are you using dos?  If not, it's probably worth getting the USB version.  It can be nice to unplug it while the cab is on.
Tiger-Heli
    • Tiger-Heli
Re:I-PAC USB???
« Reply #2 on: July 14, 2003, 04:09:33 pm »
Thanks.
USB is limited to something like 14 simutaneous keypresses and some people have had problems with it if USB keyboard support was enabled in the BIOS, otherwise, it works fine.
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
Re:I-PAC USB???
« Reply #3 on: July 14, 2003, 10:07:31 pm »
How could you possibly get 14 simultaneous key presses?  Two players, both moving diagonally and hitting two buttons, would only be 8.
KevSteele
  • Last login:January 20, 2025, 11:29:37 am
  • Retrogaming Media Mogul in Rehab
Re:I-PAC USB???
« Reply #4 on: July 14, 2003, 11:38:45 pm »
Two caffiene-addled Majohng players, with authentic control panels?  :o
Kevin
Kevin Steele, Former Editor and Publisher of RetroBlast! and GameRoom Magazine
grafixmonkey
  • Last login:October 16, 2010, 08:16:50 pm
  • must... tear self... away from... Tron...
    • My graphics/arcade/circuits site!
Re:I-PAC USB???
« Reply #5 on: July 15, 2003, 02:33:45 am »
Four people playing Turtles In Time at once, and all trying to move diagonally and perform their special "super whack" moves (A + B together) while inserting coins with the nearest convenient third appendage?  Simultaneously?
1, 2, 4, 8, 9, 10, 12, 14, 16, 17, 18, 19, 20.
I'd use PS2 port just to see that happen!    ;D
-- See my grafix, circuits and cab on my
-- new arcadey page:  http://www.bkgrafix.net
wboy
  • Last login:November 03, 2005, 05:09:19 pm
Re:I-PAC USB???
« Reply #6 on: July 15, 2003, 05:31:22 am »
Using the PS/2 to USB adapter supplied with my JPAC, I personally found I was getting interference on my arcade screen that didnt exist when I was connected thru PS/2.
Very minor, but still noticed... thus annoying.
anyone else notice this?
Re:I-PAC USB???
« Reply #7 on: July 15, 2003, 05:32:03 am »
I believe in USB mode the IPAC uses keyrepeat, whereas in PS/2 mode it doesn't.
Not sure if this has many advantages, but I was thinking of adding an option to take advantage of this in my FE (Keyrepeat = slightly less code to execute).
But on a 2-player panel I would think 14 simultaneous inputs is enough.  The most I can think of using is 2 players hitting a diagonal & 3 buttons each which makes 10.
Tiger-Heli
    • Tiger-Heli
Re:I-PAC USB???
« Reply #8 on: July 15, 2003, 07:00:25 am »
I agree, it's not a practical limitation, but it does exist in USB and not in PS/2 mode so I thought I'd mention it.
