Author Topic: PCE CD torrent with ape files (the big 500 games one) Getting it up in MALA  (Read 4083 times)
Henrik68000
  • Last login:December 12, 2010, 01:54:23 pm
Hi I Have spend a lot of this getting this to work. And i got some help from a wise guy. Now i wnat to share this.
First you need the collection of PC-E CD's Theres 500 games. Then you need Monkey program (free).
Unzip your PCE-cd collection. This takes time.
Point the monkey program to your unzipped pc-e cd collection. Let monkey program find all ape files and then pres extract files. Takes some time. Its important the the monkey program gets into all the folders to fin all ape files for all games. This can be done in one go.
After this Use windows Seach function to locate every ape file and delete them.Now you have each game in a folder with some isos, a cue, and some wav files.
Now setup Mala: You need Daemon lite. Install this. In mala point the executeble to your magic engine folder and the pce.exe. Rom path to your folder with all the game folders. Tick search sub folders! tHIS IS IMPORTANT AS EACH GAME IS IN A FOLDER BY ITSELF. otherwise it wont work. in the file extention field you shall only have 'cue' so that these are listed as games in mala. Under 'execution' you shall have in the 'precommand field the following 'c:\programmer\daemon tools lite\daemon.exe -mount 0,"%path%\%rom%.%ext%"
or ofcourse the path that fits your daemon dir.
In the commandline you shal only put: -cd:L
In the precommandline you unmount the cue file in daemon: c:\programmer\daemon tools lite\daemon.exe -unmount 0
Remember to change the dir so that it points to your daemon folder. Now you can click 'hide' on that same page.
Post me if you have trouble.
Henrik
« Last Edit: September 17, 2009, 04:41:30 pm by Henrik68000 »
