Author Topic: usb port on front of cab?  (Read 4764 times)
Shieldwolf
  • Last login:November 16, 2020, 12:48:53 am
  • SpearShield.com
« on: July 14, 2003, 03:32:52 am »
I wanted to see if anyone had a usb port on the front of their cab. I was thinking of putting a multi-port directly under my cp on the front of the cab so i could plug in guns or dance pads other extra goodies. Any thoughts?
F|end
  • Last login:October 20, 2007, 07:27:59 pm
  • I'm 250 euros away from a working cabinet...
Re:usb port on front of cab?
« Reply #1 on: July 14, 2003, 04:44:02 am »
Sounds useful! Great idea!
How about several usb ports in front of the cab?  ;D
In that way, you could connect several stuff, since your mobile phone, a usb flash drive (very useful) and a dance pad!
Pedro Vieira
Lilwolf
  • Last login:May 08, 2026, 06:33:59 pm
« Reply #2 on: July 14, 2003, 07:16:39 am »
Keyboard and player 3 / 4 controllers would also be great!
Good idea!
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #3 on: July 14, 2003, 11:49:30 am »
I'd like to incorporate USB ports in my cab or control panel, but I'm at a loss as to how to mount them without it looking like a hack-job.  Any ideas?  I was thinking about cutting out a rectangle hole just big enough for the end of a USB extension cable, but I'm not sure how to secure it.
Best Kid iPad Apps
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #4 on: July 14, 2003, 12:18:32 pm »
Look in front of my monitor.
Here's a close-up
http://www.fe.donkeyfly.com/images/y_cab_usb.jpg
I eventually will have a graphic underneith the plexi which will hide everything.
I have them on here for the same reasons mentioned, 3 and 4 player gamepads and keyboard.  Will also be hooking ddr pads to it.
There is this crayola modeling foam.  When it dries it is hard.  I plan on making caps for the ports.  I might move the ports to under my control panel though so then I wouldn't need that.
« Last Edit: July 14, 2003, 12:44:01 pm by SirPoonga »
OSCAR
  • Last login:September 06, 2018, 11:31:53 pm
  • I think Bigfoot is blurry, that's the problem...
    • Oscar Controls
« Reply #5 on: July 14, 2003, 12:32:08 pm »
I put a little 4-port USB hub under my control panel, too.  It's handy for connecting devices, but I don't do it that often.  I have an access hatch installed on the underside of the control panel for easy access to the USB  hub and panel clamps.
http://www.oscarcontrols.com/tmp/hatch-cp1.jpg
http://www.oscarcontrols.com/tmp/hatch-cp2.jpg
HeadRusch
  • Last login:September 02, 2006, 04:13:30 pm
  • ....Here you are all EQUALLY WORTHLESS...
« Reply #6 on: July 14, 2003, 12:37:03 pm »
I had originally planned to add a fan to the front of my cab, underneath my CP....well I put the 2" Hole in, but never added the fan.....tahnkfully its tucked RIGHT underneath my rather large CP so you dont see it unless you're 4' tall, or you're bending down to look for it.
Currently I have a nice little 4 port USB hub "wedged" in the round hole, it just fit perfectly.
Eventually I'll fill in the area around the hub with foam rubber or something so it looks better, but
yeah....its great for hooking up a USB trackball or a gamepad or whatever ;)
".....its like a Koala crapped a rainbow in my brain!"
_Iz-
  • Last login:Yesterday at 09:24:45 pm
  • Time to coin up!
« Reply #7 on: July 14, 2003, 01:17:38 pm »
This is exactly what I'm planning to do. I'm going to cut a rectangular hole with a slight taper so as you shove the end in from the back it wedges just before it comes out the front. I also thought I'd apply some silicone to the hole (carefully) to act as "glue" to make the plug stay. If necessary, I'd also get some of those cable clamps you use to attach wire to a wall to use on the cable behind the plug just to make sure nothing moves.
AlanS17
    • AlanS17
« Reply #8 on: July 14, 2003, 01:51:42 pm »
I plan on adding USB ports just inside the coin door. That way you can use a regular USB hub without modification and nobody has to look at it. It's totally hidden. Plus I always leave the coin door unlocked, anyways. I may start locking it soon, though, if my machine gets popular at the frat house. Gotta pay for dues somehow!  ;)
said7
  • Last login:January 24, 2012, 02:24:47 pm
  • "I smell..... NERDS" - Ogar
    • www.said7.com
« Reply #9 on: July 14, 2003, 03:01:56 pm »
Im building mine right now and I am planning a spot to incorporate a hub.
Under the front of the CP.
Check out my site: http://www.said7.com
Arcade site comming soon.
Sprucemoose
  • Last login:March 23, 2009, 03:56:10 pm
  • You Spent How Much?!
« Reply #10 on: July 14, 2003, 03:10:09 pm »
I found this on the web.  It looks like it could be incorporated into a flush mount usb hub very easily and its only $10.  Just make sure your motherboard has the 10 pin front header on the motherboard.  I think most motherboards Pent II and up have these.  It also has room for a floppy drive if anyone is so inclined.
http://www.slcentral.com/reviews/hardware/periph/antec/easyusb/
There are instructions on the site
Hoagie_one
  • Um....whats a cabinet
« Reply #11 on: July 14, 2003, 03:41:57 pm »
http://www.datapro.net/products/80-3033.html
They have several kinds available, fairly cheap
SirPoonga
  • Puck'em Up
« Reply #12 on: July 14, 2003, 06:18:11 pm »
To add mine was really easy to do.  I just got one of those USB ports that go in the pci expansion slot with the header pins.  I split the ports into a usb cable and ran the ports to a hub inside.  To cut the plexi I used the pci plate as a guide.
Sasquatch!
  • Last login:March 01, 2010, 04:11:47 pm
  • Toot-Toot!
    • Arcade Paradise
night
  • Last login:January 09, 2018, 02:08:19 pm
« Reply #14 on: July 14, 2003, 10:28:54 pm »
im having a hard time thinking of things that would be plugged in/out on a regular basis ???
i like everything permanent so u just have to pull it out.... hmm.. but what about these dance pads. i didnt they had that for PC ???
how about my nintendo power pad, i could use tha ;D
AlanS17
    • AlanS17
« Reply #15 on: July 14, 2003, 10:42:31 pm »
Well things like a gun would be pretty permanent, but a wheel would probably have to be removeable. If you have 3rd and 4th player handheld controllers those may be removeable, too. A keyboard might also be removeable if you don't have room to mount it.
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
« Reply #16 on: July 14, 2003, 10:57:01 pm »
actually, you probley could hack it... gonna get mine down to test it out. prob being getting it hooked up to a pc...
i might try it, even tho u were jokin, cool idea
It's all about the Pentiums
meta87
  • Last login:September 30, 2004, 07:36:28 pm
  • Dont Mess with Texas
« Reply #17 on: July 14, 2003, 11:00:08 pm »
From what I've heard, people buy the playstation dancepads and get the psx to usb converter. I'm thinking of doing this, the ladies like the dancepad. ;)
night
« Reply #18 on: July 14, 2003, 11:00:49 pm »
ok, i guess it just didnt click for me. im gonna have removeable 3/4 player panels, and anything extra like a wheel, i'll just slide the 3/4 out and put the wheel panel in. all guns, extra crap, etc are gonna be hidden behind a glass door.
maybe its just my superior design :P
AlanS17
    • AlanS17
« Reply #19 on: July 14, 2003, 11:12:06 pm »
A glass door? On an arcade machine? I hope it's insured.  ;)
SirPoonga
  • Puck'em Up
« Reply #20 on: July 14, 2003, 11:16:07 pm »
For me, keyboard , ddr pad , player 3 and 4 gamepads, Analog joystick,and what ever comes up in the future.  That;s the wonders of usb.
KevSteele
  • Last login:January 20, 2025, 11:29:37 am
  • Retrogaming Media Mogul in Rehab
« Reply #21 on: July 14, 2003, 11:21:54 pm »
I added a mini-USB hub from CyberGuys to my cab, next to my volume control pod:
http://retroblast.com/mameframe-details.html#Volume
It's been great for Players 3 & 4, as well as plugging in a USB hard drive for backups.
Kevin
Kevin Steele, Former Editor and Publisher of RetroBlast! and GameRoom Magazine
AlanS17
    • AlanS17
« Reply #22 on: July 15, 2003, 12:59:12 am »
Yup, that's why my plans for a set-top console emulator will use all USB gamepads so I can upgrade and use different devices.
thedemo
  • Last login:May 21, 2003, 06:30:04 pm
  • I want to rule the world
« Reply #23 on: July 15, 2003, 02:51:03 pm »
I found these a while back. They are panel mountable USB couplers from a company called L-Com. I am planning on using them to put a small USB panel in my lower coin door. Might work for you as well, just need an ab extension cable to connect to your existing USB port(s).
http://www.l-com.com/jump.jsp?lGen=detail&itemID=3483&itemType=PRODUCT&iMainCat=104&iSubCat=156&iSubSubCat=0&iProductID=3483
night
« Reply #24 on: July 15, 2003, 07:45:19 pm »
not actually a glass door.... hmmm, my screen is set about 4.5 inches back from the back edge of the CP. between the CP and monitor i have a sliding door made from the same smoked glass as the in front of the screen. you slide it back (goes under the monitor shelf) and under there will be volume, pause, light guns, headphones, etc.
Hoagie_one
« Reply #25 on: July 16, 2003, 01:55:44 pm »
1UP
  • Token Junkie
    • 1UPArcade
« Reply #26 on: July 18, 2003, 02:12:50 am »
Interesting how often we think alike, SirPoonga!   ;)  I am planning to make covers for the USB plugs on my Star Wars/ T2 panel from the tops of extra Happ pushbuttons.  These will pop in and out of the plugs as needed, keeping dust, pets, and kids out of there!  If this works out well, and if anyone else wants them, maybe I'll make them to sell...
My other job...
SirPoonga
  • Puck'em Up
« Reply #27 on: July 18, 2003, 02:14:25 am »
hehe, I was thinking more because of the way they are mounted if something spills they are screwed.
shmokes
    • Jake Moses
« Reply #28 on: July 18, 2003, 11:44:51 am »
USB ports hidden under false pushbuttons....not bad.  Not bad at all.  I might be in the market if you made these.  Surely they could not be very expensive.  Keep us posted.
Best Kid iPad Apps
Chris
    • Chris's MAME Cabinet
« Reply #29 on: July 18, 2003, 11:47:48 am »
I have one of those behind my coin door; it has mounting points for a 3.5" drive, so it handles both USB access and floppy access.  I am also going to mount a small USB hub in the overhang beneath my control panel.
--Chris
--Chris
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #30 on: July 19, 2003, 12:14:04 am »
VERY nice!  That's exactly what I'm looking for!
