Author Topic: problem after installing cap kit  (Read 1751 times)
Zanox
  • Last login:November 20, 2011, 12:25:24 pm
« on: September 08, 2009, 08:55:22 pm »
I just installed a cap kit and when I powered everything up I am not seeing any video on my monitor. I didnt hear anything pop and after disconnecting the monitor board I dont see anything damaged. The monitor is lighting up, just nothing displayed. This is a MAME cab and I can hear sound so I know the PC is working.
Any ideas?
Ken Layton
  • Guru
  • Technician
Re: problem after installing cap kit
« Reply #1 on: September 08, 2009, 09:26:05 pm »
Everything plugged back in? And plugged in correctly?
Zanox
« Reply #2 on: September 09, 2009, 09:15:57 pm »
Yes, I even discharged it and rechecked everything.
sarge
  • Last login:April 27, 2015, 01:42:54 pm
« Reply #3 on: September 09, 2009, 10:36:24 pm »
do you get raster if you turn the screen voltage up?
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #4 on: September 09, 2009, 10:51:41 pm »
double check your work .
look for solder bridges ( splashes ),  components touching , correct cap polarities.
and as previously mentioned ... board connections,  etc....
Zanox
« Reply #5 on: September 10, 2009, 06:04:24 pm »
Yes I do. I can adjust the screen size and everything, just no image from the pc.
Zanox
« Reply #6 on: September 10, 2009, 06:23:52 pm »
Its working great when I hooked it up to my JAMMA game. Must just be something wrong with my PC.
Thanks for the ideas.  :notworthy:
