Author Topic: 8 way wico 's leaf switch joystick for Robotron mame cab  (Read 3809 times)
mytymaus007
« on: September 07, 2009, 08:10:05 pm »
IM building a mame cab and want original robotron joysticks for 8 ways. Does anyone know where i can find rebuilt original robotron sticks. Im assuming Robtron had 8 way wico leaf switch joysticks correct me if im wrong
thanks
telengard
  • Last login:October 21, 2025, 02:12:46 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
Re: 8 way wico 's leaf switch joystick for Robotron mame cab
« Reply #1 on: September 07, 2009, 08:22:29 pm »
Yep, Robotron used 8 way leafs.  They did have slightly longer shafts IIRC (not sure if that is necessary for a MAME cab, I just use stock 8 ways).
As for where to get them, I've got all mine from eBay, but maybe someone will have some info on vendors.
HTH,
~telengard
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
mytymaus007
« Reply #2 on: September 07, 2009, 08:32:46 pm »
How does the stock 8 way leaf work with robotron, Also can i mount them to a standard HApp bolt pattern or is the mounting plate a differnent size
thanks
severdhed
  • Last login:November 08, 2025, 10:49:16 pm
  • RIP Dinosaur Hippo
« Reply #3 on: September 07, 2009, 10:08:44 pm »
i have some 8way wico sticks, and the bolt patterns seem to match right up with happ comp sticks
Paladin
  • Mmmm llamaburgers!
« Reply #4 on: September 07, 2009, 11:30:02 pm »
Telengard is correct about the shafts.  Robotron used 4" long shafts, most other games use 3.5".  The 4" shafts with red ball tops can be hard to find.  Even more so now that people are making Multi Williams cabinets.
