Author Topic: replacing 8 pin tube with a 10 pin question  (Read 2067 times)
iscariot
  • Last login:April 02, 2025, 12:44:33 am
« on: September 03, 2009, 12:55:36 pm »
Just wondering about this....is it possible?  I ask because I have 3 8 pin WG chasis and 3 magnavox tvs with 10 pin yokes.  Is there a way I can match wires on the chasis to the yokes?
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Re: replacing 8 pin tube with a 10 pin question
« Reply #1 on: September 03, 2009, 01:18:33 pm »
Short answer: no.
Slightly longer answer: if you have a K7000 there are 7 and 10 pin varieties.  You can swap tubes - as long as you have the corresponding neckboard.
iscariot
« Reply #2 on: September 03, 2009, 01:43:12 pm »
I got a neckboard for the other 19" tube.  Not a way to desolder the wires from the 8 pin and add the 10 pin?
SirPeale
« Reply #3 on: September 03, 2009, 03:53:11 pm »
Are they both K7000s?
iscariot
« Reply #4 on: September 03, 2009, 04:11:52 pm »
Sadly, no. I'm not near it now so I can't check. How about a 10 pin tv board and tube soldered to a chassis with 8 pins?
SirPeale
« Reply #5 on: September 03, 2009, 04:58:17 pm »
I'm not aware of a way, sorry.
iscariot
« Reply #6 on: September 03, 2009, 10:05:58 pm »
Crud.  Well, how hard is it to find a @#$!#@$ 8 pin tube?  TV repair shops all shrug and nobody is going to let me open their tv and check.
SirPeale
« Reply #7 on: September 03, 2009, 10:39:44 pm »
I have a bunch of them, and I need the other kind!
iscariot
« Reply #8 on: September 04, 2009, 11:49:37 am »
I'm wondering with a TV, since the tube has the same RGB guns on it, could one solder lines off the RGB on the neckboard somehow and just run those wires into the RGB from the jamma?
