Author Topic: Everything you need to know about mixing the Dreamcast & Arcades  (Read 19777 times)
crashwg
« on: September 01, 2009, 03:30:53 pm »
The Sega Dreamcast is a great candidate for the brains inside a home-built arcade machine because it is based on actual arcade hardware and has many arcade ports that look amazing and play nearly identically to their arcade counter parts.
Of course there are many threads in this forum that relate to this subject but finding and sifting through them can be a nightmare.  So I'm starting this thread in hopes of gathering all that information to one place where it can be organized for easy searching from within the forum structure and also as way to gather all that information to be added to the BYOAC Wiki without everyone having to learn the proper syntax of the Wiki system.
Here's hoping this works out and we can get some great information together for ourselves and future generations of BYOACers!
P.S. In order to keep this thread as uncluttered as possible I ask that you do not make a post without some sort of contribution to the subject.  If you would like to thank any members for adding stuff to this thread, do it by adding stuff yourself.  I realize this is sort of against the norm of the usually appreciativeness shown on this board but I believe the resulting thread full o'uncluttered info will be worth it.  That being said, do not hesitate to post a correction to any of the information on here.  We don't want any misinformation getting through to those who want to see the Dreamcast live on for another 10 years!
« Last Edit: September 02, 2009, 10:49:37 pm by crashwg »
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
  • Last login:January 30, 2026, 04:39:53 pm
Re: Everything you need to know about mixing the Dreamcast & Arcades
« Reply #1 on: September 01, 2009, 03:35:02 pm »
2 types of controllers make a good candiate for hacking (as an interface to controls):
Sega Official Controller - Analog triggers and joystick can be hacked, making them act as digital (on / off) in the process.  You will need to remove the black coating to solder to directions and buttons.  Has a common ground.
MadCatz Dreampad - Has a common ground.  No prep required, can solder and go.  Triggers are already digitalized, can solder directly (some claim this reduces input lag compared to the hacked triggers on a Sega Official).
crashwg
« Reply #2 on: September 01, 2009, 03:46:33 pm »
Rotatable Games
I have personally confirmed this list of games as being rotatable.  They all rotate so that the bottom of the monitor is now the right side, some rotate the other way in addition but since most do not I recommend rotating the monitor counter-clockwise or anti-clockwise for you weirdos across the pond.
The following information is the default configuration of the games.  As you will notice, most have just three buttons mapped.  Some have multiple buttons mapped to the same command which can easily be remedied by just not adding the additional buttons to your CP.  On the other hand Gunbird 2 & Trizeal have four discreet inputs.  Luckily on both games one of those buttons is a rapid fire button which just duplicates the "shot" button but pressing the button repeatedly for you.  Therefor this button can be skipped entirely allowing you to keep your CP free of buttons that will rarely be used.
All of these games have re-mappable controls.  Menus are all A=forward B=back.  The only thing I've personally noticed in any of these games that differs from this is in Gunbird 2 in which you need the "Y" button to choose "2 Character mode (1p)".  Taking all that into account, if you are planning a three button control panel, I would recommend using A, B and Y and remapping all the games to suit this setup.
I'm pretty sure this is a complete list although I would love to be proven wrong as it is unfortunate that the list is not longer.  IMO Ikaruga and Under Defeat alone are worth building a vertical DC cab.
Gunbird 2
VGA - Not Supported *
2 Player Mode - Simultaneous
DPad - Movement
A - Shot
B - Bomb
X - Close Attack
Y - Not Used **
L - Not Used
R - Rapid
* a simple hex edit will enable VGA output but the game looks like turd)
** while not used "in game" the "Y" button is required to select "2 Character mode (1p)" which allows you to alternate characters as a single player
Ikaruga
VGA - Supported
DPad - Movement
A - Shot
B - Change
X - Not Used
Y - Not Used
L - Not Used
R - Release Power
Karous
VGA - Supported
2 Player Mode - None (Single Player Only)
DPad - Movement
A - Shot
B - Sword
X - DFS
Y - Not Used
L - Not Used
R - Not Used
Psyvariar II
VGA - Supported
DPad - Movement
A - Shot
B - Bomb
X - Not Used
Y - Not Used
L - Not Used
R - Not Used
Radilgy/Radirgy/Rajiruji*
VGA - Supported
DPad - Movement
A - Shot
B - Sword
X - Absnet
Y - Not Used
L - Not Used
R - Not Used
* Rajiruji is believed to be the correct spelling by my wife who has studied a small amount of Japanese
Shikigami no Shiro II
VGA - Supported
DPad - Movement
A - Shot
B - Bomb
X - Rapid
Y - Not Used
L - Not Used
R - Not Used
Triggerheart Exelica
VGA - Supported
DPad - Movement
A - Shot
B - Anchor
X - Not Used
Y - Not Used
L - Bomb
R - Bomb
Trizeal
VGA - Supported
DPad - Movement
A - Shot
B - Trans
X - Bomb
Y - Rapid Shot
L - Not Used
R - Bomb
Under Defeat
VGA - Supported
DPad - Movement
A - Shot
B - Bomb
X - Not Used
Y - Not Used
L - Not Used
R - Screen Mode*
* You probably don't want this button on your CP unless you want people to ask you to fix the game when they press it and the screen rotates back to horizontal and since your screen is now vertical the game is crooked.
« Last Edit: September 02, 2009, 11:49:44 pm by crashwg »
Lemme say it again
crashwg
« Reply #3 on: September 02, 2009, 09:07:55 pm »
Connecting your Dreamcast to VGA without soldering or any of that junk
There are a few different VGA adapters that have been produced since the Dreamcast hit the scene back in '99.  Below are some pictures of a few.  As far as I know these pictures are not public domain so please don't add them to the Wiki as that would violate the rules.
If you have one of these adapters please let us know your experience with said adapter.
« Last Edit: September 02, 2009, 09:11:31 pm by crashwg »
Lemme say it again
crashwg
« Reply #4 on: September 02, 2009, 10:39:49 pm »
I have an official VGA adapter, model number HKT-8100 produced by SEGA themselves.
Most of my time spent using the adapter has been with Ikaruga and Under Defeat on a 21" CRT and I have to say that it is a sight to behold.  I no longer have the CRT but rather a 1680x1050 LCD and as you would expect the picture doesn't look quite as good but it is still awesome.
Unfortunately these things are pretty rare and ebay prices for the official VGA adapter usually break the $80 mark.  If you choose to go this route you won't be disappointed but you should consider the 3rd party adapters that are out there.  Perhaps some additional reviews from other members could shed some light on the quality of them...
Lemme say it again
DJ_Izumi
  • Last login:November 04, 2023, 04:19:22 pm
« Reply #5 on: September 02, 2009, 11:58:07 pm »
I have a LexTek Dream Cable.  It's a pain in the ass without instructions.
It has a male and female VGA cable on it.  WHy?  It's a passthrough.  So you can hook it up to your PC monitor and see your PC signal, power on your DC and it auto switches.  It also has RCA composite switches.  IT DOES NOT HAVE A SELECTOR SWITCH.  So how does it decide if it should do composite or VGA?  Auto sensing.  On the 'Input' VGA cable there must be SOME LOAD, or it will NEVER switch to VGA mode.  This is done as hooking it up as they intended however this doesn't work because it adds noise to the passthrough (No noise on DC signal output).  However you can add load other than connecting it to the output end of a PC.  Actually just snapping a DVI->VGA adaptor onto the input end is enough to put load on it and auto-switch it to VGA output.
I got this adaptor without instructions and it took a bit to figure out what was wrong with it.  Naturally my first attempt was to just snap it onto a VGA monitor and expect VGA output.  ...No.  Eventually I figured it out however.
It does look nice however.  Dreamcast, 640x480, that's pretty.  My 21 Sony Trinitron P1110 tubes are also built into a steel cage underneath the ABS plastic shell, which means the shell is decorative and not structural.  I can actually turn my monitors sideways for Shmups that support vertical mode.  I intend to do this for a Shmup setup at an anime con. :D
northerngames
  • Trade Count: (+18)
« Reply #6 on: September 03, 2009, 11:50:01 am »
The clear hais vga box in the 2nd picture has my vote
with hands on experiance for that model I can confirm it is easy to use and does the job for vga and arcade use.
you can also open the case and clip 1 wire or the other and get them to display native 15K 25K and 31K
some of the others pictured I have not used but I have seen others make post where they had nothing but problems trying to get them to do 15K on arcade monitors.
The hais you just open the case and clip one wire and it's ready to rock.
The official DC vga cable is rare and costly and should not be hacked up in my opinion.
Some arcade monitors will require a video amp like ultimarc sell's some monitors are fine but some will require the extra voltage increase otherwise they have a dull/dim display.
if you want to run multiple console's like jamma PC DC etc.:
 make your control panel wires run to a DB25 and you write each and every pin signal down to the T and do the same for your DC controllers and also the same for your jamma harness PC etc. then you can have all of them hooked up to a DB25 switchbox and be able to swap from DC PC jamma and what not without any tools or figuring out what wire goes where with the tangled mess of wire's in between type thing.
This way you want PC turn the knob and its done then you want to change to DC turn the knob again and then it is done etc. so much easier faster and cleaner in the end and it also make's it more convienent to add more console to it that way too.
if something acts up just unplug it and pull it out fix it and plug it back in just like you would on your xbox ps2 gamecube etc. no need to rewire the cab all over again becuase of terminal blocks or other means of manually playing around with wires & tools each and everytime & trying to figure out what one goes where type thing.
use DB15's for the video on a DB15 switchbox
here is a quik official pcb pinout I made real quik and will polish up later
Instead of plugging the stock 1/8" PC speakers stereo jack into the hais vga box I used one of these RadioShack Gold Series Audio Y-Adapter Instead.
http://www.radioshack.com/product/index.jsp?productId=2103710
That way your DC sound can now plug into your exsisting arcade sound amp and speakers or jamma setup through the RCA cables.
Me I have everything ran to a home theater surround sound system set instead of using the stock arcade speakers and amp or the over rated and over priced PC speaker sets I went with a real name brand surround sound home theater reciever and speaker set becuase of the rca style adaptor  :lol
« Last Edit: September 03, 2009, 12:41:21 pm by northerngames »
versapak
  • I am t3h GAY!!!
« Reply #7 on: September 03, 2009, 03:14:16 pm »
This is the one I have, though I have an actual 19" PC monitor in my cab, so I dunno how well it works for going straight to an arcade monitor. It works (or worked I guess, as I just swapped an Xbox 360 into that cab a couple days ago) excellently for VGA though. :)
« Last Edit: September 04, 2009, 08:03:19 am by versapak »
Franco B
DJ_Izumi
« Reply #9 on: September 03, 2009, 08:15:04 pm »
Most NAOMI cabs are 31khz though not all.  I'd just stick with a VGA RGB monitor for a Dreamcast based cab myself. :D
Franco B
« Reply #10 on: September 04, 2009, 03:02:15 am »
I'm not entirely sure I get what you mean.
Btw, this is an awesome thread. I'm sure it will be of great use :)
It would be nice if we could come up with a list of games that use the d-pad. I could add a few that I know and then we could add others to it if you like? Unless there is a list out there already.
« Reply #11 on: September 04, 2009, 07:30:32 am »
Umm, all but like 2 use the D-Pad...   ;D
Franco B
« Reply #12 on: September 06, 2009, 06:56:22 am »
Really? Cool. Saves me a job then  :D
Here's the pinout to the Naomi I/O board/AMP plugs. Useful if you want to connect your pads to the controls:
Couple of pad hacks courtesy of the masterful Haruman with AMP connectors added by moi.
gnateye
  • Last login:December 05, 2011, 11:22:36 am
  • 4 cabs and counting!!!
    • natty's arcade
« Reply #13 on: October 02, 2009, 11:23:49 am »
i also made a little VMU extender using 2 cheapie memory cards so i can have a memory card/VMU slot exposed on the control panel as some games have fun animations on he VMU screen and for easy switching of mem cards as i have a lot of them. see pics here as well as pics of my dreamcast cab. i used to have a 17" vga monitor and the generic black box vga converted, the cable eventually broke at the box though and i wanted a larger scrren for the size of my cab, i now use a 24" tv with svid fits perfectly and looks good, not as nice as the vga but still pretty good. i also have 2 control extension cables wired thru my control panel and coming out flush with the sides for light guns and fishing controller as well as adding pads for 4 player games. this cab actually gets used more then either of my 2 mame cabs as the kids LOVE it!
http://cosmicbreaks.com/arcade/dc_VMU/index.htm
disclaimer there are a lot of progress images if the cab, but the one midway thru with the large tv and finished marquee and whatnot is the final cab. they arent in chronological order sadly
ark_ader
  • I glow in the dark.
« Reply #14 on: October 03, 2009, 04:54:21 pm »
Lies
Madcatz have no pre drilled holes.
You have to solder the contacts.
You can get VGA by shorting the pins on the AV interface or you can do this:
http://www.instructables.com/id/Sega-Dreamcast-VGA-Mod/
Franco B
« Reply #15 on: October 03, 2009, 10:26:38 pm »
Errrm, did he say anything about pre drilled holes?
Yes, soldering is a good idea  ::) (Unless you think [hot glue] is a good alternative.  :D
By no prep required he means you can solder directly to the traces.
  • Last login:Today at 12:34:14 am
« Reply #16 on: November 05, 2009, 08:56:38 pm »
I loved this thread so much, it made me decide to put a Dreamcast into my jamma cocktail cab!
Long live Dreamcast!
crashwg
« Reply #17 on: November 06, 2009, 08:46:09 pm »
Could someone please get some of this information into the Wiki?  I'm afraid that I'm just no good at the Wiki organization...  :banghead:
Lemme say it again
« Reply #18 on: November 25, 2009, 12:44:11 am »
Looking at the wiki page, it looks like it's already up there (or someone just put it there).
I wanted to mention that the game-list you have there is great, but it doesn't mention the rotation directions available to these games. For instance, Ikaruga and Under Defeat both support rotation, but rotate clockwise only. Whereas Psyvariar II has an option to rotate to both left and right directions.
This is vital information dependent on how you've mounted your monitor.
« Reply #19 on: November 30, 2009, 04:55:57 pm »
I've got a little problem with the VGA Box hack...
I modded my VGA Box to put out 15kHz, and connected it to my Electrohome G07 through Andy's Video Amplifier. The sync is fine, I don't have any scrolling or picture cropping issues when viewing on my arcade monitor. The problem I am getting is after the DC boot logo the screen starts fading out to white. I haven't tried hooking the VGA box directly to the monitor, without the amplifier yet, but perhaps that is what is giving me this problem?
I have separated the negative syncs out, so they're no longer composite, and I've also made sure my Amplifier is putting out separate syncs as well.
But doesn't the VGA Box put out Positive sync's?
I can't imaging the sync's being related to this, like I said, I don't get any scrolling issues...it seems to be more of a colour signal thing.
Any thoughts?
« Reply #20 on: November 30, 2009, 05:44:28 pm »
Try a different game? Some DC games are incompatible with the VGA box.
« Reply #21 on: December 01, 2009, 12:17:34 pm »
I tried a few other games, and I'm still getting the white problem.
I then connected the VGA Box with a spliced-up VGA cable directly to the monitor without the amplifier and the white problem did not show up. So it's definitely a problem with the combination of the VGA Box and Ultimarc's Video amplifier. Though, without the amp, the image is dark due to the weak video signal.
My bet is that Ultimarc's video amp+vga box is creating a bit too much amperage for my monitor to handle. Gah! Are there any other options to getting a solid picture out of the VGA Box onto my G07 monitor? Perhaps there's a different amp I could get, or somehow modifying the VGA Box to give me the right signal amounts?
I really don't want to abandon the idea of hooking up the DC to my cab...
« Reply #22 on: December 01, 2009, 12:27:57 pm »
I don't think you can modify the VGA box itself, can you modify the video amp to bring the power down some?
Also, have you tried reducing the brightness on your monitor?
« Reply #23 on: December 01, 2009, 12:53:12 pm »
Yeah, I've tried toning down the brightness, but unfortunately the whited-out colours signals are coming into the monitor that way. So turning down the brightness only makes the white screen grayer.
Perhaps modifying the amp is doable, I'll check out Andy's site description of the amp and see what I can do. Otherwise I might have to figure out another avenue to get the DC working on my monitor, without the VGA Box. :(
« Reply #24 on: December 01, 2009, 10:05:23 pm »
Hmm, modifying the amp isn't really do-able, nor would I want to since it's connected for my Mame PC video.
So I have to come up with a solution with the VGA Box (or scrapping the VGA Box entirely). I'm wondering, if I were to sever the connection for the 5v output from the DC to the VGA box and let the Amp make up for the 5 volts instead, do you think that would work?
I also noticed that the DC has 2 pins that output 5v and 12v. I'm wondering if either of these would effect the gain levels...
Please forgive my electrical "noobery"...
ark_ader
« Reply #25 on: December 24, 2009, 02:39:01 pm »
Some DC games are VGA compatible and some are not.
The only proper way to get around this is a Magic VGA or similar without looking at a component solution (expensive) The games look crisp on the LCD monitor and no ghosting or interference noise. I have a KWorld 1440 and it does the job.
I use the Xarcade with the DC and 1440 so practically any arcade related game except light gun games work with this setup.
BurgerKingDiamond
« Reply #26 on: November 04, 2010, 11:28:12 am »
I want to get a VGA box to use s-video to my CRT. The light guns games will still work right? I read a review on amazon and someone said that light guns don't work with the box. He wasn't specific on whether it was the box itself or just through VGA (which I already know won't work). If it's s-video I don't see why it wouldn't work, but I don't want to buy it and find out I was wrong. Thanks.
-Welcome to the Fantasy Zone.
SNAAKE
  • Trade Count: (+29)
« Reply #27 on: November 04, 2010, 11:39:33 am »
dreamcast light guns work with vga monitor as is. I played for years when I had my cabinet with vga crt. should work fine with s-video. forgot to email you doing it right now :burgerking:
BurgerKingDiamond
« Reply #28 on: November 04, 2010, 11:44:15 am »
ok. The dude must have had it hooked up through VGA to an LCD computer monitor or something and just assumed that meant the whole thing was worthless for light gun games.
SNAAKE
« Reply #29 on: November 04, 2010, 11:49:48 am »
obviously. most(if not all..who knows) dc vga boxes are pretty much the same. dc light guns doesnt even come with that composite "pass through" cable like ps1/ps2 guncons. it just...works :applaud:
DJ_Izumi
« Reply #30 on: November 04, 2010, 03:00:05 pm »
That's because the Maple Bus ports actually have an extra pin that sends the sync data up to the controller.  The Xbox1 does the same, that's why it's basically USB but has 5 pins instead of 4.  :)
northerngames
« Reply #31 on: November 04, 2010, 04:48:15 pm »
Any thoughts?
should be running in composite not seperate at least on my rig and it worked flawless.
I could be wrong on this but I am thinking there was also a trace or solder spot that had to be removed/cut on the video amp to manually change from composite to non composite on the video amp itself I could be wrong on that though becuase its been awhile.
« Last Edit: November 05, 2010, 11:34:26 am by northerngames »
BurgerKingDiamond
« Reply #32 on: November 18, 2010, 04:06:38 pm »
ugggggggh. why isn't my dreamcast working with s-video? the image is all inverted like a photo negative. whit is black etc.... Also the image is unstable it doesn't line up right. I know it's not the cable, and I know it's not the TV. I've tested them both. Has anyone heard of this problem? BTW, tried on 2 seperate DC's.
Mikezilla
« Reply #33 on: November 22, 2010, 01:08:34 pm »
Damn! As you know BKD, I was gonna hook up my DC to play MVC2, to my cab, which has S Video. Ill be watching this thread considering I was going to do that to my cab. I wish I could help you out!  :dizzy:
« Reply #34 on: November 22, 2010, 02:46:06 pm »
Any thoughts?
Hmm, I didn't get an email notice of this thread post. Weird.
When I find some time, I'll give this a try...thanks.
northerngames
« Reply #35 on: November 22, 2010, 05:59:01 pm »
unless your using the same monitor that is irrelevant.
are you guys tryinng to run S-video to a 15K arcade monitor?
BurgerKingDiamond
« Reply #36 on: November 22, 2010, 06:05:24 pm »
nope s-video on a TV. I know the TV and the cable are both fine. For some reason through the DC it's f****
northerngames
« Reply #37 on: November 22, 2010, 10:30:39 pm »
Ahh I see it's either a bad pin on the video port or a bad video chip.
check the solder points for the pins and if your not into soldering get a new DC.
I never had a problem with one in S-video on any tv so that is why I think it is one of the two above then.
northerngames
« Reply #38 on: November 22, 2010, 10:41:40 pm »
BKD also are you using a straight up S-video cable only or are you using a vga box with a male/male cable or some other type box in with the S-video cable?
also what is the make and model of the TV your trying it on?
BurgerKingDiamond
« Reply #39 on: November 23, 2010, 10:14:09 pm »
I've tried on two different CRT's. One is  Sony trinitron, and the other is a Phillips. They are both fine for s-video, since I'm currently using them for other consoles at the moment.
I'm using the s-video out from a VGA box (the VGA out works fine btw). The dude I bought it from said that he used the s-video without any problems... Oh yeah, I tried it on 2 Dreamcast's as well, so all signs point to it being a problem with the box.
I may just get a DC s-video cable and bypass the VGA box and see if I can narrow down where the problem is. Then again I might just live with composite... I have other more important stuff (fixing up my candy cab right now) than this issue right now.  :angry: :angry: :angry:
