Author Topic: ArcadeVGA - Can't install drivers on XP  (Read 1631 times)
Collywobbles
  • Last login:September 29, 2009, 04:31:48 pm
    • Collywobbles.net
« on: August 31, 2009, 06:50:35 pm »
Hi there,
I'm trying to install the ArcadeVGA drivers on my XP box but I just get the error:
"The display driver is not compatible with the display adapter(s) installed on your system"
I'm using AGP version which I believe is a modified ATI Radeon 9200.
I've installed XP using a standard ATI card (ATI Radeon 7200). This device installs okay and I can see the device driver for it. I tried running the cat-uninstaller.exe but that didn't help. I've no idea why the ArcadeVGA drivers won't install. I'm using drivers provided on an Ultimarc CD. I also tried the driver downloaded from the website but got the same error.
Any help appreciated!
« Last Edit: September 01, 2009, 05:11:14 am by Collywobbles »
Collywobbles
    • Collywobbles.net
Re: ArcadeVGA - Can't install drivers on XP
« Reply #1 on: September 01, 2009, 03:55:36 pm »
Okay - I've fixed this problem.
There seem to be 2 scenarios which cause this error:
1. Your motherboard AGP drivers aren't installed (you'll probably be in VGASAVE mode)
2. You don't have the ArcadeVGA card installed
I encountered both of these in various combinations and got very confused.
