Author Topic: Nanao Monitor Identification  (Read 2622 times)
acevedor2
  • Last login:May 25, 2024, 08:21:24 pm
« on: August 29, 2009, 04:55:49 pm »
Hey all.  I have a VF2 that I am trying to get a cap kit for.  The problem is, I can't figure out what size the monitor is.  I know, I know, how difficult can it be to figure out the size on a monitor?
The tube is a Mitsubishi a63LCC-11X.  The board is a NANAO board.  However, I can't tell if it is a MS8-26SU 26" color or a MS8-25FA 25" color.
Any thoughts?  Thanks!
Dedicated - Working:
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Pool Sharks - Pinball
Projects:
Pole Position
Pole Position 2
grantspain
Re: Nanao Monitor Identification
« Reply #1 on: August 29, 2009, 05:36:50 pm »
i have never seen a 25" nanao but i have seen loads of 26"-why do you need to change the caps?
acevedor2
« Reply #2 on: August 29, 2009, 06:25:32 pm »
Several horizontal lines at the top 1 1/2 " of the screen.
Thanks.  I think I'll go with the 26!  :cheers:
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Projects:
Pole Position
Pole Position 2
grantspain
« Reply #3 on: August 29, 2009, 06:40:33 pm »
classic fault that one mate,its a resistor and a cap-if you can wait for tuesday then i can tell which exactly as i forget for the moment due the chassis overload :scared
acevedor2
« Reply #4 on: August 30, 2009, 12:24:57 pm »
Thanks, sure can!  I appreciate it.  I'll hold off on my order to Bob to make sure I order the correct resistor.
Cheers!
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Projects:
Pole Position
Pole Position 2
grantspain
« Reply #5 on: September 02, 2009, 02:49:09 pm »
i finally got round to checking the chassis,
C433 10uf 25v-please check though as it may 100uf
R433 2.2k 0.125watt
These are the two components that cause the fault you describe
the following is when you lose full vertical deflection
R436
C437
Q401
Q402
acevedor2
« Reply #6 on: September 02, 2009, 11:27:00 pm »
Thanks!  I certainly appreciate it!   :cheers:
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Projects:
Pole Position
Pole Position 2
